Sagging rear end fix?Lowering front end?Suggestions?
Old Mar 21, 2010 | 11:56 PM
mj_39's Avatar
hey guys i own an 08 g35 sedan with tanabe df210 springs, the drop was pretty much the same in all 4 corners, however, i've recently done some audio work and now im slightly lower in the rear than my front. Can anything be done to drop the front end on the car a bit? Ive read that you can raise the rear a bit with spring isolators but im really starting to like how low the rears sitting wondering if there's any way to even it out?
thanks
Old Mar 22, 2010 | 05:42 AM
IvoryPearl07G's Avatar
install stock springs back into the rear.
if you want to go lower and match, try 350z front springs.
Old Mar 22, 2010 | 02:16 PM
mj_39's Avatar
thanks for the info!, theres a thread on cutting your spring rubber top mounts, wondering is that possible for the front of our cars?
thanks!
Old Mar 22, 2010 | 02:46 PM
johnnyzee's Avatar
I don`t believe the front has enough meat to do any cutting...the rear for sure. Your best and easiest bet to even it out would be the spring isolator route. PM me if you need the link to the isolator DIY thread.
rezendvous420
May 31, 2020 01:26 PM
newg37
Jul 26, 2015 09:32 AM
itschuckster
Jul 25, 2015 08:07 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
