Adding one-touch to the rear windows for 07?
Old May 5, 2010 | 12:22 PM
InfinitJazz's Avatar
I found a master power window switch panel from an 08 which has one touch on all four windows. I have an 07 which only has the one touch for the front windows. Since it's the master window control switch panel I am thinking of replacing, would this make all my windows one touch? Are the wire harnesses for 07 and 08 the same making it a plug and play affair?
Old May 5, 2010 | 01:47 PM
Austin713's Avatar
im not sure but i have 1 touch on mine and its an 07. Im guessing that came in one of the packages? i would assume they are the same.
Old May 5, 2010 | 06:50 PM
rpm&my_G35's Avatar
Yes - Premium pakage.
Old May 5, 2010 | 08:43 PM
Thanks for the help!
Old May 5, 2010 | 10:07 PM
kool_yaar's Avatar
^ so does it work on yours or not? maybe you just need to reset the windows if you have the premium package... else you can try swapping out for the 07 premium master window switch, but i doubt that they would be any different.
Old May 6, 2010 | 10:51 AM
Whoever the previous owner was, didn't get any options on this car. No premium package or any other optional package. I'm surprised it has a sunroof! I just wanted to see if changing the master switch out from mine which is auto down for just the front two windows, to one that is auto down for all 4 windows would actually make all my windows one-touch, or if it's something more involved like replacing all the window switches. Not sure if I want to drop the cash to find out it won't work.
Old May 6, 2010 | 12:49 PM
kool_yaar's Avatar
Ask rick @ riverside infiniti, send him a PM and he can confirm for you and then you can buy the master switch from him if it works.
Phenomenon9
Aug 9, 2015 01:34 AM
Jussaku
Interior
Jul 29, 2015 04:13 PM
will091195
Jul 27, 2015 09:19 PM
apintojr
Jul 23, 2015 10:52 AM
newbdriver01
Jul 15, 2015 06:10 PM
