3M DiNoc CF for grille?
Old Jun 17, 2010 | 06:30 AM
Ggosht's Avatar
+1 on the door handles
Old Jun 17, 2010 | 08:34 AM
soundmike's Avatar
Reading up more on the material, it looks like 3M actually does not recommend removing the vinyl if you have it applied on painted surfaces as it may damage the underlying paint/clear, or leave some of the substrate behind.
Old Jun 17, 2010 | 05:47 PM
2GoRNot2G's Avatar
I think it will look great, Mike. I say go for it.
Incidentally, here's a pic of my new grille. It's on the car now... just need to take some pics and post them up. Also had my radiator shroud done at the same time.
Old Jun 17, 2010 | 09:45 PM
toymachine2009's Avatar
I wonder if it would look good to do the vinyl on the whole hood on a black car.
Old Jun 18, 2010 | 01:02 AM
Shurik355's Avatar
Don't think so, cause there is not that big of a vinyl available. And if you do it piece by piece it just wouldn't look right + it would be just "ricy" to do something like that lol
Old Jun 18, 2010 | 02:08 AM
J2S2M's Avatar
Adrian, that looks great!!! Did you wrap that yourself? Looks like you put clear coat on it too.. very nice work!!!
Old Jun 18, 2010 | 02:25 AM
kennymo's Avatar
they do make a big enough peice. and if you do it. just make sure you spray a clear coat over it to give it a gloss look and i think it would look awesome
Old Jun 18, 2010 | 02:56 AM
sunny G-35 NYC's Avatar
I dont think it will have any effect on your paint when you remove it. Just make sure you use the specific remover for this stuff, and make sure you have enough vinyl because you dont want to be stretching it to a point it doesnt look good.
Old Jun 18, 2010 | 08:34 AM
soundmike's Avatar
That looks very nice! Is it the same wrap material, or is that real CF? Either way, looks very nice. I'm still on the fence though.
Incidentally, i just talked to a local graphics shop and they can get a 337.5 sq.ft. sheet of automotive vinyl that's enough to cover the entire car. The roof or hood can be done in single units.
I sure hope so. Unlike the automotive stuff that allows for up to 4 years of easy removal, the Di-Noc's substrate can detach from the top layer if you try taking it off near the end of its life cycle. Its akin to having residue left when removing tint.
Still reading up on more details.
Old Jun 18, 2010 | 12:39 PM
2GoRNot2G's Avatar
Thanks. It's done in real CF, but if done right the vinyl wrap will look just as nice.
Do you have an extra front grille? Like I bought the midnight black grille, so I have my factory grille as a spare. If so, just try wrapping the extra grille and see how you like it.
Old Jun 18, 2010 | 07:29 PM
Shurik355's Avatar
Well the thing is if you spray clear coat over it, it wouldn't really stick. For the clear coat to stick you need to sand the surface, otherwise it won't stick and will start pealing off in the future.
We do removal of very similar black out tapes in the body shop that many manufacturers use on the pillars and in other areas. If will peal right off with the heat gun, if you apply right amount of heat. It can also come right off with the rubber eraser wheel we use, you just have to be very careful not to burn the paint when using it. Well that's what we use at the shop for this kind of sticky stuff.
Old Jun 18, 2010 | 07:37 PM
4p81's Avatar
Originally Posted by ultraman1017
here is mine -
OHhh that's beautiful...Now why didn't I think of that?!?!?!?!
Picture Share
Feb 4, 2018 12:41 PM
_evilMonkey_
2nd Gen (V36) Sedan
Nov 22, 2015 06:21 PM
vQFamily
Sep 30, 2015 01:17 PM
itgogitrev
Sep 25, 2015 10:28 AM
