Quote:
I use the best of the best. Originally Posted by TheDizzle
JDM newspaper. nice
Quote:
Eh, doesn't really matter anymore. I just did it the hard way.Originally Posted by salvador312
You seriously don't have tools!! lol. REALLY easy to remove the trunk chrome lip.
^salvador... you can use a water/soap combo that makes the vinyl much easier to use. Once you have it set the way you want it you use a blow dryer or heat gun to dry it and bammm! perfect...it also makes it a little more stretchy eliminating bubles and wrinkles
Updates pics. I touched up a paint a bit today. Grill came out perfectly.
Quote:
Too late but here is the DIY on removing the OEM chrome spoilerOriginally Posted by apexi957
There isn't a write up for either of them. I tried to remove the rear trunk lid following the write up for the last gen G, but there are these screws I can't even remove nor reach.
https://g35driver.com/forums/v36-diy...r-install.html
Oh wellOriginally Posted by rpm&my_G35
Too late but here is the DIY on removing the OEM chrome spoilerhttps://g35driver.com/forums/v36-diy...r-install.html
I give you props for what you did.
But Im surprised you didn't do any sanding first... Hope fully it doesnt start chipping, cause then it will look cheap.
I vinyled mine out.
I vinyled mine out.
I vinyled mine out.
What do you mean? He sanded all of the chrome...as he said above the 8th pic in the first post, "Sand every chrome piece down with 400 grit until it looks like brushed aluminum"Originally Posted by LightsOut
I give you props for what you did.But Im surprised you didn't do any sanding first... Hope fully it doesnt start chipping, cause then it will look cheap.
I vinyled mine out.
Props to you OP. Ive painted all of my interior parts but i used a spray gun, but one thing you could do that will help you out is sanding technique. I START with 400 and then move up to 600 then 800 and then 1k (wet sanded) then prime it....then hit it again with the 1k (not wet sanded) then spray a layer of paint or two, then after you have cleared it and its dry wet sand it again with the 1k lightly and the finish will be so smooth and flawless. Hope that helps some. Ill take pics of the pieces i painted and post them.
oops didnt catch that part
Quote:
What interior parts did you do? Door handles?? I want to wrap my interior with cfOriginally Posted by KBL281
I guess I'm the minority here.
I don't mean any disrespect, but that looks awful.
The grill looks a little better in the newest pics, but the trim does not look like it was evenly applied.
Maybe it's just the pics.. I don't know.
Quote:
yeah so did i at first but took to long to come in and i painted hahahaOriginally Posted by apexi957
I popped out the door handle side pieces and my aluminum pieces around my indash screen, pretty much everything aluminum that i could pop out or unscrew was painted. The first time i did it the paint was to much of a light metallic so i added some black and repainted it today it looks SICK, im letting them dry right now before i put them back in but ill post pics PROMISE ;-)
lol
