$300 to change AT fluid!
Exactly what Ive been doing! Ive done 2 drain and fills and I'm a little under 60k. I think I will be doing another drain and fill on the next oil change. This way the ATF never gets to sludge and get too dirty.
i did mine at around 45k miles myself. 12quarts at $11 a piece.
-unhooked the cooler line going to the radiator
-put it in a 15qt bucket
-started it
-poured in the fluid one after another into the tranny dipstick hole
-turned off the car at the 12qaurt mark in the bucket
fluid gradually went from the brown dingy look back to pinkish
I would like to do it again at 60k miles which might be another year from now
-started it
The dealer I go to uses a machine similar to the BG machine and the cost is something like $280. I asked them why don't they do it per the FSM. Their response was they've used this machine all this time and they haven't had a problem.
So I think I'm going to do myself, buy the 15 qts of S-Matic fluid and do it per the FSM. May also record it on a video camera so I have it on record.
FS[SoEast]: 2006 DG Coupe Part Out - mrev2, projectors, etc
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
2007, case, change, cost, fluid, flush, g35, infiniti, inifiniti, nissanmatic, price, replacement, substitute, transfer, transmission
