Advice - Vibration
Old Aug 11, 2010 | 02:45 PM
ParkStr8's Avatar
Advice - Vibration
Ok...almost 3 years on the 08 S - great so far overall.
Recently tho I'm having issues with a very slight vibration anywhere above 45 or so. I just put 2 new wheels and new tires on my 19's. Roadforced balanced by an expert here in LA. Also have new brakes...but that would not cause vibration unless i was applying brake force.
Anyone have any idea what could cause this? Suspension or bearing issue?
I've checked the TSBs...
Thoughts?
thanks,
Old Aug 11, 2010 | 02:56 PM
blnewt's Avatar
Do you still have the old wheels & tires? If so switch them out and see if it still has an issue.
Old Aug 11, 2010 | 03:25 PM
Deezflip's Avatar
bent wheels perhaps? Not just a bend on the lips, but more like a wobble from side to side. You can't really see it unless you take a look at it while it's mounted on an axle and giving it a little a spin.
Old Aug 11, 2010 | 04:09 PM
ParkStr8's Avatar
They are literally brand new...and it's not a vibration like out of balance or alignment...i would know that...
it's hard to describe...but i've had these 19's on since I purchased...and have literally replaced all for wheels - the front two last week. I did bend a rim by hitting a pot hole - hence the replacement. DId that do anything to suspension?
-s-
Old Aug 11, 2010 | 04:27 PM
LightsOut's Avatar
SIETESG
rotors are warped.
Old Aug 11, 2010 | 05:26 PM
Austin713's Avatar
check your wheel bearings on the hub of the wheel that hit... you may have messed that up.
Old Aug 12, 2010 | 01:26 AM
Mississaugag35x's Avatar
^ I second that thought. If you hit a pothole the issue could be a wheel bearing although you would generally hear a slight grinding noise and I take it thats not the case. Don't think its a warped rotor as you would only feel that when braking.
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
6spdGspot
Oct 5, 2015 01:55 PM
dcsbh1
Oct 1, 2015 03:15 PM
Learned Hand
Oct 1, 2015 09:02 AM
