Recording CD's... Am I missing something?
Old Aug 19, 2010 | 11:05 AM
CerveloR3-SL's Avatar
So I recorded a CD in my in dash player, and it appears the CD is totally recorded as it says 14/14 and it now will not let me push the record button again.
However... when I remove the CD all the songs dissapear, and nothing new shows up in the music box?!?
What am I missing?
I did not see the screen prompt me to do anything after the CD was burned?
I am guessing that there has to be something else I need to do.
Thanks for your help guys.
Old Aug 19, 2010 | 11:15 AM
mrclowny's Avatar
In my car, I just stick in a music CD and it automatically records it to my music box. No user interaction is required.
Old Aug 19, 2010 | 11:29 AM
Well I am wondering where the music is suppose to show up? After the CD has been recorded.?
Old Aug 19, 2010 | 11:52 AM
mrclowny's Avatar
It will show up in the Music Box. Are you sure your CD recorded? It will show on the screen 2 of 10, 3 of 10 as it's recording from what I remember.... The CD will need to be in WMA format.. or watever the music format is....
Old Aug 19, 2010 | 12:05 PM
Yeah it did all that... it went all the way to 14/14. And now it registers as if i recorded it because I cant select record.
I look in my music box and there is nothing.
Its a real CD not a burned one, and I am wondering if its write protected or something.
I will try a different disk.
Old Aug 19, 2010 | 12:40 PM
Jayhawk815's Avatar
Yeah, I'm not sure what to say. Definitely try a different disk and see if it works.
Old Aug 19, 2010 | 01:43 PM
LightsOut's Avatar
SIETESG
after it burns the cd, all the songs take awhile to transfer to the hard drive.
as for the peeps who put the cd and auto records, that feature can be changed to manual.
I would hate for the CD to auto record.
on my G37 once the cd is in, ill burn as normal, then once everything has transferred, I press disc button again to get to my music box.
Old Aug 19, 2010 | 02:56 PM
NEVERMIND.....
User error.
I just did not know that there was more to the music box than the 12 songs showing. I guess i will have to figure out how to display the Music box items better....
I found my recorded music. It worked just as advertised.
Old Aug 19, 2010 | 03:09 PM
LightsOut's Avatar
SIETESG
it organizes them by alphabetical order
Old Aug 19, 2010 | 03:19 PM
terrycs's Avatar
Also keep in mind the track names will only show up if the album is recognized by gracenote.
Old Aug 19, 2010 | 03:26 PM
yeah I am going to have to play with mine as it is grouping them by artist or playlist somehow...
Only when i began to toggle thru the artists did I realize that the CD was there along with a ton of others.
Anyone know if these things get deleted when you reset your ECU or if your Battery Dies?
Old Aug 19, 2010 | 03:43 PM
LightsOut's Avatar
SIETESG
no they dont. they're in the hard drive.
Old Aug 19, 2010 | 06:54 PM
armoredmoonman's Avatar
How do I delete the existing recordings? Previous owner recorded bunch of musical CDs... Although I've been using the compact flash, I'd like to start recording some CDs onto the HDD.
Old Aug 19, 2010 | 08:38 PM
AesonVirus's Avatar
Tracks can be deleted from the Music Box Settings screen.
You can delete one track, or all Music Box content.
4-52 in the manual
Old Aug 19, 2010 | 10:14 PM
pinkii's Avatar
Once I record a cd I go into the musicbox and hit select by date and it will show up. It wont let you record a cd after you recorded it so that is why it wouldnt let you hit the record button again.
