Brake PEDAL squeak?
Old Aug 20, 2010 | 04:22 PM
pianofrk4's Avatar
Brake PEDAL squeak?
Hey Guys,
I am just starting to have a problem with my brake pedal on my 2007 G35x Sedan. Every time I release the pedal, I get a "sucking squeak" noise.... like when you pull a straw out of its hole on top of a lid. But it has sort of a higher pitch sound.
So its like a "semi-squeak"? u may say...
Anyone know how to remedy this? it is really annoying.. it happens EVERYTIME i RELEASE the brake pedal...
Any input, suggestions, greatly appreciated
THanks!
Old Aug 21, 2010 | 10:21 AM
JZeezG35's Avatar
WD40 is your friend...
Old Aug 22, 2010 | 07:17 PM
djfarhan's Avatar
my dad's fav solution to EVERYTHING! ;-p
Old Aug 23, 2010 | 08:44 AM
pianofrk4's Avatar
who would've thought... Thanks guys, it worked
Old Aug 25, 2010 | 07:10 PM
lgjt1982's Avatar
I have the exact same problem.
I actually was going to spray wd-40 on the pedal but I couldn't because there were awful lot of wires going on under the pedal.
did you ignore the wires and spray over them?
or was there a certain part you focused on?
Old Aug 26, 2010 | 11:44 AM
pianofrk4's Avatar
I just sprayed everywhere that had hinges and turning pivots/joints, etc. and let it soak for a bit. I avoided spraying anything towards the back firewall end tho.
xx7sephiroth7xx
Brakes
May 3, 2023 07:07 PM
alessandro
Oct 8, 2015 09:29 AM
TNRocker
Sep 21, 2015 08:36 AM
Blindside360
Sep 18, 2015 09:00 PM
