My G died & I was stranded!!! WTF???
Old Aug 24, 2010 | 11:37 AM
stanfna's Avatar
Exclamation My G died & I was stranded!!! WTF???
I have a 07 G35s...no engine mods...(just the stuff in my signature)...with 62,000 miles.
I was driving back from the beach this past weekend and my car died! I had the cruise control set at 85 and and was just cruising. all of a sudden the cruise turns off and a bunch of lights on the dash lit up. i lightly pressed the throttle and there was nothing. I immediately pulled off to the side and when I came to a complete stop, i noticed the engine was dead but everything else was working as normal (radio, windows, air, etc.). so i turned the car off and then tried to start it. the starter ran...but the car would not start. the dealer said the starter was turning the crankshaft but not the cams. he also said it would take a couple days to take the engine apart to figure out "what broke".
anyone ever have this happen? anyone have a clue as to what happened?
thanks!
Old Aug 24, 2010 | 11:50 AM
vp-g's Avatar
that sucks!!!! you probly ran out of oil?
Old Aug 24, 2010 | 11:56 AM
Project's Avatar
Fuel issue?
Old Aug 24, 2010 | 01:33 PM
Sammy23's Avatar
lol was there gas in the car????
Old Aug 24, 2010 | 01:36 PM
neight's Avatar
uhoh, judging by your mods; it was probably your keyhole delete keep us updated!
Old Aug 24, 2010 | 01:58 PM
vp-g's Avatar
no keyhole??? is it push start?
Old Aug 24, 2010 | 02:43 PM
Irrelevant's Avatar
If the dealer is correct and the crankshaft is turning but the cams aren't, the most likely culprit is probably a timing chain or belt.
If this let go, there may be more serious internal damage if a valve and piston tried to occupy the same place in space and time.
The good thing is it seems you should be covered under the powertrain warranty. The bad is it might be a while before you get your car back.
Old Aug 24, 2010 | 02:58 PM
stanfna's Avatar
All the fluids were good. The dealer thinks it may have been the timing chain. He mentioned the possibility of needing a new engine.
Old Aug 24, 2010 | 03:06 PM
vp-g's Avatar
timing chain in such a new car? wow!
Old Aug 24, 2010 | 03:09 PM
stanfna's Avatar
i just talked to the dealer...they are giving me a Kia for a loaner!!!
Old Aug 24, 2010 | 03:15 PM
HotRodG35's Avatar
Thats a first for me, haven't heard of timing chain issues. As for the issue of valve damage these engines do not have valve clearence issues with broken timing chains using stock cams.
Old Aug 24, 2010 | 03:49 PM
viceversa's Avatar
did you hear anything from the engine when this happened? any type of odd noise at all?
Old Aug 24, 2010 | 03:51 PM
stanfna's Avatar
no...but we did have some music on in the background. we were talking when the engine stopped.
Old Aug 24, 2010 | 03:53 PM
plainomega88's Avatar
A kia for a loaner, thats a double whammy. Hope everything turns out OK.
Old Aug 24, 2010 | 04:53 PM
CreativeDesignZ's Avatar
wow a kia for a loaner huh, i didnt even buy my car in this state or from a dealership and my infiniti dealership gives me loaners all the time, usually 09+'s
