Tune w/ HFC's
Tune will increase the performance and make your car run great!! Maybe sometime soon Motordyne will come out with a pleneum spacer or Mrev 3 or something for you guys to make your motor's awesome as well. If you don't plan on doing anything else then I would just go get a tune then. It will be worth it in performance gains in the engine plus the engine will be running at its prime at all times.
Get a tune if you don't plan to do any more bolt ons.
Cats are the most restrictive part of the exhaust and you can expect 5-10 whp from the cats alone. With a tune you could see increases of as much as 15 whp is my guess.
Don't expect noticeable change from cats alone. I still think a full cat-back is required if you want bang for the buck and noticeable gains.
I would only worry about drone on certain systems.
The Fast Intentions system has no drone, even on the highway.
Those dynos on g37 showed a measurable difference with just cats so why shouldn't I expect to notice it? If anything, I'd think I shouldn't expect to notice the difference from just cats to cats w/ a cat-back. That's gonna net all of 4-5 more whp? 5hp isn't "noticeable" until you're looking at .1's or .01's in the quarter or on the track.
Hexxum001
Forced Induction
363
Nov 8, 2015 11:58 PM
G35s-Q8
V36 Engine, Exhaust, Drivetrain & FI
22
Aug 21, 2009 08:54 PM
