GT-Spec Install
Old 09-26-2010, 08:07 PM
ParkStr8's Avatar
I've installed all the braces now...and yes Mr.Michael - the car now feels much stronger from a rigidity standpoint. Handles better too - expecially on any kind of turn. I stand by it should feel this good coming from the factory.
Also - While I was at Riverside Infiniti having the install done....played in all the cars...LOVE the new M56S. Insane detailing on even the gauges. If it were not so big - id get it. But the 2012 G should fall in line with the new design ethic - and be a hot ride.
Old 10-11-2010, 03:59 PM
ParkStr8's Avatar
Long weekend here....so got some mods done.
1. GTSpec front tower brace and 4 point front subframe braces.
2. Side marker blinker mirrors wired up.
3. "Ghetto" rubber seals for all 4 doors - makes a HUGE difference on noise.
and the second most important.
4. Sound deadener in all 4 wheel wells above liner.
I cannot express how much of a difference the deadener makes when driving.
The road noise is reduce dramatically. I was thinking when this was paid off to get a 370z as a second car...but everyone on that forum complains about the roadnoise...and many have done the wheel well liner. It works.
I've attached the link to the liner i bought. Only took an hour and 1/2 to do all 4 wheels. Much faster with lift and impact wrench.
http://www.b-quiet.com/extreme.html
See attached pics.
Next weekend - LED fogs, Custom MGP Caliper covers, and re-tinting of the fogs and tail lamps...
http://www.calipercovers.com/
Then I'm done for a bit.
WHEW!
Attached Thumbnails GT-Spec Install-cimg0042.jpg   GT-Spec Install-cimg0044.jpg   GT-Spec Install-cimg0045.jpg
Old 10-11-2010, 05:14 PM
CerveloR3-SL's Avatar
WHEW!
Where did you get the rubber seals for your doors?
I have never seen anyone do that before? I imagine it could make a huge difference.
Old 10-11-2010, 05:19 PM
LakeShore_Slate's Avatar
im jealous. i like it. i dont recall what the brace is on top of the engine cover? i claim ignorance
Old 10-11-2010, 06:32 PM
If your being serious its called a Strut Tower Bar/Brace
Old 10-11-2010, 06:51 PM
ParkStr8's Avatar
I think i go the rubber at HomeDepot...it's about 1 inch wide and 1/8" thick. Door has a nice "thunk" now when closing. But that's also because the entire interior of the door has BQuiet inside it, too.
Old 10-11-2010, 07:14 PM
jelloman's Avatar
How much of the bquiet thing you use for all four wheelwells? is 12 ft enough? And did you just stick them on the inside of the wheelwell?
Old 10-11-2010, 07:19 PM
ParkStr8's Avatar
I used almost 3/4 of a roll...I can't remember exactly which one I bought...but i used and entire roll for the interior - not including the headliner...
Old 10-12-2010, 10:56 AM
Gedan35's Avatar
where did you get the turn signal blinkers from? can we see a closer picture?
Old 10-12-2010, 04:50 PM
Mrpeeng's Avatar
Will that 6 point GT spec brace fit on awd models? does this replace that cross bar(crossmember?) in the center of the car?
Old 10-13-2010, 02:23 PM
kool_yaar's Avatar
nice job! i might have to look into applying all these seals and deadening to my aging car soon....
Old 10-13-2010, 07:07 PM
ParkStr8's Avatar
You'll h ave to check with GTSPec about the X models. Not sure. The braces and sound deadening are the best mods - from a comfort and driving standpoint one can do.
-s-
Old 10-13-2010, 10:17 PM
Mike75's Avatar
I was told by a GTSpec vendor on here that the front lower bars won't fit the X. The rest do.
Old 10-14-2010, 09:14 AM
mishmosh's Avatar
A GT Spec rep said the best bang for the buck is in the rear bars/braces anyways.
  #30
Old 10-14-2010, 01:21 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
Yes.
I have installed it on an X for another member here.
Quick Reply: GT-Spec Install
