parking brake noob question
Old Oct 8, 2010 | 02:34 AM
samsizzle's Avatar
my question is regarding the use of the parking brake.
Are you only supposed to engage it on a hill? When I dont use it on a flat surface and take my foot off the brake pedal to get out of the car, the car moves forward and back. Will this wear out the gears over time? when the parking brake is engaged there is no movement whatsoever.
I've always wondered which was better. thanks
Old Oct 8, 2010 | 07:38 AM
G35Now!'s Avatar
Moderation-free
Typically you only need to engage it on a hill. If you stop on a level surface, as long as you are completely stopped there should be little to no motion once you let off the brakes, and Park will hold your car in place.
Old Oct 8, 2010 | 10:24 AM
Ozzfest's Avatar
I have always had the habit of setting the parking brake, letting off the brakes, then put it in gear or in park. No matter where I park, hill or flat.
Old Oct 8, 2010 | 12:42 PM
jelloman's Avatar
Well since the G is RWD, shouldn't putting the engine in Park already lock the wheels in place and it can't rotate? Wouldn't that make the parking brake a redundancy?
Old Oct 10, 2010 | 12:35 PM
rustyeleio's Avatar
+1, better safe then sorry. Doesn't hurt anything to engage it. It is a separate brake system from the disc so no significant wear and tear.
Old Oct 10, 2010 | 02:25 PM
stardust's Avatar
The transmission is not a kickstand. USE the parking brake, its there for a reason
Old Oct 10, 2010 | 04:04 PM
armoredmoonman's Avatar
Use your parking brake... I usually put the car in N engage the parking brake, then take my foot off the brake pedal and put the car in park. Especially when you are not on level. Try it out yourself, when parking brake is not engaged and if there's even a slight incline you will feel your car pop out of Park very rough. I'd use it.
Old Oct 10, 2010 | 04:09 PM
mihalis's Avatar
i wish auto gs had handbrakes -_-
as25656800
Aug 9, 2015 07:25 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
kinetek
Aug 3, 2015 04:25 PM
joedaddy1
Jul 28, 2015 02:58 PM
mushu
Jul 15, 2015 03:55 PM
