60k Warranty Bumper-to-Bumper
Old Oct 8, 2010 | 06:39 PM
Ivanr77's Avatar
Hey There!
I recently purchased an 07 G35-s with 58k miles on it. The bumper to bumper warranty is about to expire and I was wondering if anyone knew of a good "checklist" of items that I should inspect myself prior to hitting that 60k point.
A few things I already noticed and had the dealer fix were:
1. Driver side headlight not turning smoothly around corners; replaced headlight assembly
2. Single Rear Passenger side LED light was out; replaced rear taillight assembly
3. Front rotors had vibration and noise when braking; resurfaced rotors and replaced brake pads
4. Cup holder plastic clip was broken; fixed clip
I am looking for as many things to fix as possible before my warranty expires. If you know of something "common" that most G35s suffer from then please let me know so I can get it inspected and fixed as soon as possible!
Thanks for the help.
Old Oct 8, 2010 | 10:09 PM
baileyt35's Avatar
I don't know why they didn't give you new rotors, heat shield and pads under the tsb but oh well..
Just a few things I had replaced under warranty:
*TSB on valve body 3 times (slight shudder on acceleration)-not common issue on G's
*TSB on sunroof, outside lining cracking (replaced sunroof)
*TSB weather stripping on all four doors
*TSB on gas tank (I could only fill it about half way), replaced some kind of ring
*TSB on steering wheel and all door handles (replaced door handles and steering wheel)
*TSB on driver seat (driver seat would rock slightly when braking)-not common issue on G's
Old Oct 9, 2010 | 11:43 AM
Ivanr77's Avatar
Bailey, thanks for the feedback. I'm going to spend some time today inspecting those areas on my car!
Old Oct 26, 2010 | 08:30 AM
Ivanr77's Avatar
Bailey, was the replaced steering wheel and door handles a result of the coating on both areas peeling off or getting scratched off easily or for something else?
Also, do you know of some good resources that I can go check out for additional TSBs?
I found a gov website: http://www-odi.nhtsa.dot.gov/tsbs but I actually did not find all of your TSBs on there.
Old Oct 26, 2010 | 08:36 AM
baileyt35's Avatar
The steering wheel and door handles were replaced because they were badly scratched. I "think" members on here posted the tsb's but if not I just asked the dealer to research it they should know anyway. I would just say there is tsb out on so and so and they would say o.k.
Old Oct 26, 2010 | 08:58 AM
kool_yaar's Avatar
infinitihelp.com
Old Oct 26, 2010 | 05:21 PM
baileyt35's Avatar
Originally Posted by kool_yaar
U duh man!!!
Old Nov 3, 2010 | 10:55 PM
Ivanr77's Avatar
Thanks everyone for the help...right at 59950 miles I got the following things fixed:
1. Weather stripping for Driver-side door replaced, other 3 doors had adhesive applied.
2. Driver-side armrest was replaced due to scratches
3. Cup holder replaced (Spring in the plastic clip that holds the cups was broken)
4. A/C Compressor replaced. We had (and still have) belt noise when the A/C is on...the dealer replaced the A/C compressor to "fix" this.
Old Nov 4, 2010 | 06:44 AM
baileyt35's Avatar
*TSB air conditioner was loud so they replaced the ac/compressor right at 59,990miles.
And the black shiny outter door panels between the windows. I forgot what they are called but it was with the first few months I owned the car.
Old Nov 4, 2010 | 02:00 PM
Rutland's Avatar
were the brakes resurfaced/replaced under warranty?
Old Nov 4, 2010 | 09:29 PM
baileyt35's Avatar
Rutland, not sure if this question was directed to me. But yes, they replaced all heat shields, all rotors and pads under warranty.
Old Nov 5, 2010 | 03:38 PM
Rutland's Avatar
It was directed to the OP as he said "Front rotors had vibration and noise when braking; resurfaced rotors and replaced brake pads", but thanks for answering. I should check to see if I can get that done as well.
f22raptor
Mar 18, 2016 08:50 AM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
heynow
2nd Gen (V36) Sedan
Oct 28, 2015 05:09 PM
