First mod
Old Oct 25, 2010 | 08:34 PM
renegadeSHADOW's Avatar
First mod
I am currently in the process of acquiring a 2007 g35s sedan and I'm trying to decide what my first mod should be. The choices are:
1) Stillen Ultra long Cold Air Intake
2) 19" Rims
3) Tanabe coilovers aimed at 1.5" drop
Which one should I do first?
Old Oct 25, 2010 | 08:40 PM
mj_39's Avatar
3, 2 ,1 that would be my order
Old Oct 25, 2010 | 08:42 PM
gtoor1990's Avatar
Tanabe Coilovers
Old Oct 25, 2010 | 08:43 PM
TORETTO's Avatar
coilovverrrrrrsssssssssss
Old Oct 25, 2010 | 08:48 PM
iiiiiekoiiiii's Avatar
3/2/1.
Old Oct 25, 2010 | 08:49 PM
CandlestickPark's Avatar
ill Sedan
3...2...I would skip 1 and do other things.
Old Oct 25, 2010 | 08:50 PM
platinumg35x's Avatar
I concur....3/2/1!
Old Oct 25, 2010 | 09:08 PM
ChinkyChoy's Avatar
LED's it always starts with a LED light then it just gets outa control...
but yes 3-2-1
Old Oct 25, 2010 | 09:14 PM
baileyt35's Avatar
3 2 1
Old Oct 25, 2010 | 10:07 PM
Q8y_drifter's Avatar
3 2 1....
Old Oct 25, 2010 | 10:12 PM
So it seems like the overall consensus is coilovers so that's what I'll go with and probably have enough for rims by the spring. Thanks for the input guys!
Old Oct 26, 2010 | 12:00 AM
black_sedan's Avatar
I would do both 2 & 3 at the same time. Or at least do 19" wheels and run lowering springs until you've got enough funds for full coilovers.
Old Oct 26, 2010 | 12:51 AM
salvador312's Avatar
Go 2 then lower with some Eibach. You might like the springs and not get coilovers. If not go 3, and 1. Instead of 3, I would get a diffuser and front lip.
Old Oct 26, 2010 | 07:40 AM
Don't lowering springs alone damage the stock shocks?
Old Oct 26, 2010 | 08:02 AM
youngG's Avatar
it make the life of shock last a little shorter
