How much does the OEM rims weight?
Old Jan 6, 2011 | 09:56 PM
theaudir8fan's Avatar
Hey, guys
I just want to ask if anyone know how much does the OEM G35S sedan and G37S coupe rims weight.
Thanks in advance for the answer.
Old Jan 6, 2011 | 10:00 PM
Greekboy115's Avatar
Here you go...
G37 OEM Wheels Specs
Sport
Front: 19"x8.5". Cast aluminum. Made for Nissan/Infiniti by Enkei. Weight: 26.5 lbs. Bolt pattern 114.3 x 5 Offset +43
Tires: Bridgestone Potenza RE050A 225/45/19 92W. UTQG 140AA, weight 27 lbs., tread depth 10/32"
Rear: 19"x9". Cast aluminum. Made for Nissan/Infiniti byEnkei. Weight: 27.5 lbs. Bolt pattern 114.3 x 5. Offset +45
Tires: Bridgestone Potenza RE050A 245/40/19 94W. UTQG 140AA, weight 30 lbs., tread depth 10/32"
2nd GEN G35 Sedan OEM Wheel Specs
2007-2008 18" sport wheels
Front: 18x7.5 +45mm offset (appx 23.7lbs)
Rear: 18x8.5 +50mm offset (appx 22.4lbs)
Old Jan 6, 2011 | 10:02 PM
Thanks you so much for the info
Old Jan 7, 2011 | 11:08 AM
CerveloR3-SL's Avatar
Originally Posted by Greekboy115
Here you go...
Sport
Any idea how much the 17" wheels weight.
The 05-06 and the 07+ versions?
Old Jan 7, 2011 | 12:10 PM
Jayhawk815's Avatar
Why would the wider rear wheel weigh over a pound less than the front?
Old Jan 7, 2011 | 02:19 PM
You know what I never really gave it a second thought. Here is what I used for my info..
http://forums.nicoclub.com/g35-g37-o...s-t342067.html
Old Jan 7, 2011 | 02:51 PM
HJ22L's Avatar
are the wheels that come with the G35xS staggered?
Old Jan 7, 2011 | 03:00 PM
Jayhawk815's Avatar
No, they're 7.5" all the way around.
Old Jan 8, 2011 | 12:07 AM
EnviedG35's Avatar
The front wheel weighs more because it has a lower offset so it has more mass on the hub area. The rear wheel is a high offset so the hub area is much smaller. Thats why the front is slightly heavier than the rear.
Old May 6, 2013 | 03:57 PM
StratoMX5's Avatar
Anyone know the answer to this?
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
netcbc
Wheels & Tires CDN
Aug 25, 2015 09:42 AM
NemesisGee
Aug 11, 2015 07:10 PM
mushu
Jul 15, 2015 03:55 PM
