Remote starter for G35Tech 07 Auto 4 Dr Sedan
Old Jan 10, 2011 | 11:15 AM
G3507Tech's Avatar
Hi ,
I just bought G35Tech 2007 Auto transmission and trying to find after market compatible remote starter.
Pleas throw some ideas.
Thanks in Advance!
Old Jan 10, 2011 | 01:31 PM
cwepruk's Avatar
I have a Compustar two way. I'd look into something that works with your smartphone now. Most brands should offer that.
Old Jan 10, 2011 | 02:39 PM
G3507Tech's Avatar
yes, I have seen at best buy and they are selling viper $199 and also for smart phones application $199.
which one is less messing up with wires?best buy did not answer my question.
Old Jan 10, 2011 | 06:06 PM
kool_yaar's Avatar
I have viper 5701 i think and it has worked great over the past 2 yrs, any newer viper 57** model should do the trick.
Old Jan 10, 2011 | 06:19 PM
Anton_Chigurh's Avatar
i called a Ziebart near me and they wont even touch an infiniti to put a remote start in
Old Jan 10, 2011 | 07:59 PM
pattyballs's Avatar
Wasnt there a problem with installing an auto start stated a while ago? If i recall a lot of people were having a problem because in order to start our cars the key Fob has to be in the car. Does anyone know if they have solved this problem? because i have been looking into buying/installing an auto start and just want to make sure it will work. thanks
Old Jan 10, 2011 | 09:50 PM
kool_yaar's Avatar
^ well i had my installed 2yrs ago with the old FOB module but now there is a new DEI module thats installed along any aftermarket remote start in any i-key car without having to use one of your fobs with the module.
Old Jan 10, 2011 | 10:07 PM
pattyballs's Avatar
^Niceee! thanks for the info
Old Jan 17, 2011 | 09:15 AM
I3LAZEN's Avatar
I got a 07 g35x sedan and got the Clifford 5702 installed. That has the 2 way lcd pager w/ auto start.
With the module, it doesnt require a key fob to be in the car so i got to keep both of my key fobs. Everything worked perfectly fine for a couple weeks and then....
The only issue I had was that after a few weeks of having the alarm in, when i got into the car to start it... i pressed the brake, pushed the button to start it & it just went to ACC. Pushed it again & it went to ON but it wouldnt start the car for nothing. The auto start worked perfect but I just couldnt get the car to start. After trying & trying, I finally got the car to start. Took about 20 tries.
I took it to the dealer & they determined that the alarm shorted out the BCM & the BCM had to be replaced. I got the alarm removed & after that, the bad BCM worked perfectly fine with no starting issues. The BCM was replaced anyway by the dealer since it was under warranty & I never put anything back in.
The installer of the alarm said he did everything correctly & that the alarm couldnt of been the issue but it obviously seems that way since as soon as it was removed, I had no starting issues.
Old Jan 17, 2011 | 10:51 AM
jimboG35x's Avatar
best buy wants a additional 225 to install it caus ei need more peices.I got the viper 5101 but they only install whats in the box for free..But they needed other parts like relays and so one so its an add 225 to install it.Im still q's on doing it thats alot of money
Old Jan 17, 2011 | 12:27 PM
TheTrance's Avatar
youcan use any remote start just make sure they do the wiring right. use idatalink bypass. if they dont do the wiring right, you'll get weird BCM issues such as tire pressure light and etc. all they need to do is use a -ve ignition to power the unit. i know a lot of people got their BCMs replaced because the dealer thought the BCM is dead, when it actually isnt. also they gotta diode isolate a wire so that you dont get a "no key" light coming on...
Old Jan 17, 2011 | 01:48 PM
cwepruk's Avatar
Call your local dealer and find out who they use.
I went with a system that was used by the shop recommended by a couple Nissan dealers familiar with the set up. Mine was $600 under the table since I had a friend with a connection. Not cheap, but the dealer was charging $1100 (!!!!).
Old Jan 17, 2011 | 01:56 PM
bluedevils95's Avatar
That's a lot of $$$$$ for that. Do you use it a lot?
Old Jan 17, 2011 | 02:40 PM
dmb4040's Avatar
The local Infiniti dealer (at least where I am) still install the remote start with the extra keyfob. My coworker just had that installed and I wasn't too impressed (especially since his car has the "key is still in the car" sound/beep every time he opens his door).
I didn't realize that there are systems existed that can get around the need for a keyfob.
Old Feb 2, 2011 | 03:56 PM
bdlee76's Avatar
Just get it installed at an Infiniti Dealer. I got mine installed when I bought the car at the dealership. Infiniti warrantied and works with existing fob by hitting the lock button twice. No need to carry an xtra fob. I paid something like $550. I don't remember the brand.
