Stock 2007 g35 sedan headlights
Old Jan 30, 2011 | 07:45 PM
Jamesg35slate's Avatar
Question Stock 2007 g35 sedan headlights
I know that the stock headlights are xenons but it doesnt seem bright at all. Also, it seems like it points too low to the ground. Is there a way to adjust the headlights so they point a little higher?
Thanks
Old Jan 30, 2011 | 08:08 PM
Geemy's Avatar
Behind your headlights is a long adjuster with a 6 point at the end for a socket. Its usually locked with a U guider. I took my U guiders off so that i can adjust my headlights from my engine bay. You could get to these from the wheel well if your U guiders are still on.(most likely if your stock) Also to make them brighter.... I swapped the lens with clear STI lenses from theretrofitsource.com.. works great.
soundmike's Avatar
Yep. https://g35driver.com/forums/v36-int...locations.html
Just a note, although you can adjust via the *****, there is a note on the FSM about needing the CONSULT tool to further adjust it (esp. for auto-leveling). I have done it via **** only and it seems to be working fine.
Old Jan 30, 2011 | 08:13 PM
Thanks guys. Im thinking of putting HID 8000k. Do you reccomend?
Old Jan 30, 2011 | 08:17 PM
jimboG35x's Avatar
i have 6k ilove them but i think im gona adjust them also ,for the guy who changes the lens how hard was that and is it alot clearer
Old Jan 30, 2011 | 08:21 PM
jimboG35x's Avatar
do u have any pic of thatlens u put in anynight shots.I upgraded my hids and i would like to install this lens how hard was it thanks
Old Jan 30, 2011 | 11:19 PM
liljohnny's Avatar
No, don't do it! If you think your lights are not bright enough now, changing them out to 8000K will make them much worse. Stick with 4300K for maximum brightness. Certainly no higher than 5000K!
Old Jan 31, 2011 | 03:05 PM
Geemy's Avatar
Here is the link to the DIY
https://g35driver.com/forums/v36-diy...lens-swap.html
It tooks about 5 hours with 2 guys...because we painted the housing also. Id say 3-4 hrs for just the lens swap.
Before and afters are
4300k+stock lens
then 4300k+clear lens
and last shots were 8000k+clear lens.
8k would make your lights less bright but more blue. I think 6k would be perfect for you.
Old Feb 1, 2011 | 12:09 AM
jimboG35x's Avatar
thanks i appreciate it,i heard s2k lenses r sick but i think im gona do the st-r i like the cut off very nice,jus thope it comes of crisp like that
TWASkyliner
Feb 8, 2020 08:00 PM
Blakelyg35
Aug 15, 2015 12:12 PM
laksjd84
Jul 24, 2015 05:12 PM
