Manual shift 2nd to 3rd gear - engine noise
Old Jan 31, 2011 | 07:16 PM
scorpkev's Avatar
G35 Sedan RWD
Just got 07 G35 Journey with all packages.
After a few days of driving, I notice the following:
On manual shift:
1st to 2nd gear - smooth
2nd to 3rd gear - after 4kRPM, the higher the RPM when I shift, the louder this "noise" gets, clearly is from engine. Not sure if this is the engine knock noise or pinging as I never countered any sort of engine noise from my previous cars. I assume engine ping is more metallic noise, right? I assume engine knock is more deep tone noise which is what I am hearing now. It happens almost every time from 2nd to 3rd.
3rd to 4th gear - mostly smooth, may hear very light "engine knock" occasionally.
On automatic: every gear is smooth and no sound from engine
Anything I should be concern with?
Should I reset ECU for any good reason?
Old Feb 1, 2011 | 08:54 PM
scorpkev's Avatar
G35 Sedan RWD
I am the only one on this forum suspect of having some sort of "hard shift" or "engine knock" issue??? Damn, I must have a bad luck picking out this car then...
any advice anyone?
Old Feb 1, 2011 | 09:09 PM
Anton_Chigurh's Avatar
You still have the powertrain? Under 70K? Take it in to infiniti.
My 07 G35x will do a semi hard shift every now and then when i floor it to get around someone or accelerate really hard..but that's the only time it does it. Thats in normal shift mode. I feel its normal as every car i have had has had a hard shift now and then when doing an almost WOT
Sorry i can't be more help
Good luck!
Old Feb 1, 2011 | 09:28 PM
soundmike's Avatar
Quick question, what kind of gas do you have on there?
Old Feb 2, 2011 | 08:16 AM
Q8y_drifter's Avatar
Are you saying you hear the knock/ping when shifting?
Old Feb 4, 2011 | 05:27 PM
greg_atlanta's Avatar
2008 G35 Journey Sedan no sunroof
i get a rattling noise on high rpm upshifts from 1-2 and 2-3. i was told it's the exhaust resonators and that it's normal. but i still don't like it.
Old Apr 19, 2011 | 06:07 PM
SN00P's Avatar
CLUB MODERATOR
bumpl please ... every get it figured out ...
in 1st gear at higher RPM's im starting to get a loud like scratching sound from the engine and 2nd-3rd gear shifts i get a small sound but not like a high rpm WOT in 1st ... anyone ???
madmax032
Drivetrain
Jan 18, 2016 10:41 AM
Cskeet
Drivetrain
Dec 3, 2015 09:18 PM
Ednica87
Sep 5, 2015 02:59 AM
Blakearold
Aug 19, 2015 10:20 AM
tehmoonrulz
Jul 19, 2015 10:44 PM
