How to remove paint from rubber strip?
Old Feb 3, 2011 | 07:31 PM
G3507Tech's Avatar
Need help!
My car was painted or buffed but there is plastic strip between bonnet and grill that is also painted. I would like to remove the paint from the strip when I called dealer for price,it would $200.
I am trying cleanup nicely with any good paint removers(not to spoil the strip) instead of spending that money.
Old Feb 3, 2011 | 09:49 PM
pattyballs's Avatar
Look in the detailing section, all i can suggest is trying a little rubbing alcohol. But make sure you dont get any on the actual body of the car.
Old Feb 3, 2011 | 09:54 PM
speedracerg35's Avatar
you should be able to scrape it off with your fingernail. if not, you can use paint thinner/reducer to get it off, then treat it with armor all. if all fails, you can replace the strip. it should be less than $50.
Old Feb 3, 2011 | 10:24 PM
RemmyZero's Avatar
i believe there is a goo-gone without alcohol that is safe for plastics and rubber, you might want to check that out. or use a mr. clean magic eraser...just don't get it on the paint or wash immediately if you do.
Danielek
May 1, 2022 01:28 PM
cmesidewayz
Sep 29, 2015 09:28 PM
G35CO
Sep 4, 2015 09:27 AM
