I really need a response quick.
Old 02-07-2011 | 03:44 PM
salvador312's Avatar
I am at the tire place right now. They selling me these tires for $150. Take them or leave them. I checked the year and they are 2005.
http://www.atlantistire.com/prod-18022.htm
Old 02-07-2011 | 03:46 PM
1hotvq's Avatar
depending on tread left... id say they were pretty cheap.
Old 02-07-2011 | 03:50 PM
Thead is friction good. About 80% left. But I was wondering if the year of the tire matter!!
Old 02-07-2011 | 03:54 PM
1hotvq's Avatar
as long as they look good...no cracks and the rubber is still very pliable.
Old 02-07-2011 | 04:01 PM
mishmosh's Avatar
5 years is not bad. I would pass if they were 8+.
Old 02-07-2011 | 04:07 PM
Kuneff's Avatar
You should be fine with that... $150 is a smokin deal.
Old 02-07-2011 | 04:18 PM
InfinitJazz's Avatar
My question is, are you sure you want runflats? The ride and handling is not going to be as good as a standard re050 tire.
Old 02-07-2011 | 04:26 PM
Austin713's Avatar
if your putting them on the back its probably fine, but you run the risk of the tires being out of round. you will get that womp womp womp sound whenever your at low speed. happened when i picked up some used fk452s with 90% tread on them.
Old 02-07-2011 | 04:27 PM
Thank you for the quick responses!! I got them and about to install them. I take a pic of the ones I had!! Badness to it's max!!
Old 02-07-2011 | 04:31 PM
I am actually trying to save money. This is the only ones I found same brand and good condition. You really think it's gonna be really noticeable!
Old 02-07-2011 | 04:34 PM
Depends on your driving style, if you don't really push your car at all, then you won't notice.
Old 02-07-2011 | 04:48 PM
I really don't think this is the proper way to jack the car!!!
Old 02-07-2011 | 04:52 PM
Actually, it is the correct jacking point for most rwd cars. And it is correct for the G. Just make sure they have jackstands on each side where the normal oem jack would go to stabilize the vehicle.
Old 02-07-2011 | 05:09 PM
Thank you Jazz!! I am going home happy!! I seriously thought they were screwing up!!
Old 02-07-2011 | 05:15 PM
JOKER's Avatar
CLUB MODERATOR
yep. I jack my G up like that all the time when I need to get to rear tires or something else.
