What do you think about these wheels?
#31
Can someone advise what size tires I should go with?
I am currently lowered on H&R springs and running -1.8 to -2.0 camber in the front and -1.1 to -1.2 camber in the rear (have camber kit only in the rear). I know I have plenty of space up front but I am a bit worried about the rears. The specs on these wheels are 19x8.5 (+22et) all around. Do you think I can get away with 245/40 19's or should I go with 245/35 19's all around?
#32
#34
#36
#37
#40
Thanks!
#43
PRODRIVE GC-014i
^ Refer to the link for additional info on these wheels. And yes, they come in 18's as well.
#44
PRODRIVE GC-014i
![Big Grin](https://g35driver.com/forums/images/smilies/biggrin.gif)
I'm probably going to scoop up some 18x9.5X and 18x8.5.
EDIT: What size did you get them in? And have you decided on the tire size too?
#45
I believe these wheels are discontinued. I picked mine up on ebay. However, the seller only has them in 19's (19x8.5 +22et).
You can also contact Ravspec and see if they can still order these in the sizes you are looking for. Ravspec used to sell these around the forums. If Ravspec can't get em, most likely you are out of luck unless you are able to find some used ones.
