differential and transfer case oil clarification
Old Feb 15, 2011 | 11:19 PM
RedBaronK's Avatar
Ok as far as I know, a 2nd generation 2008 g35x has both differential oil AND transfer case oil, but someone today told me that the x only comes with a transfer oil because its Awd... and there's no differential oil to replace. He basically said a differential is found only in red cars. I am 90% sure this person is wrong, but can anyone verify this?
Old Feb 15, 2011 | 11:20 PM
RedBaronK's Avatar
*rwd not red... auto correct sucks.
Old Feb 16, 2011 | 12:38 AM
kool_yaar's Avatar
wow... he's wrong, i dont understand why people claim stuff that they are not certain about. AWD sends power to all 4 wheels when needed so there HAS to be a rear differential to get that power to the wheels plus the transfer case... Anyways you need to service both transfer case and rear differential.
Old Feb 16, 2011 | 10:17 AM
Austin713's Avatar
i hope that someone isnt your mechanic. if so RUN. if he is your friend ask where they got that information from, then put them in their place. god knows how many forums he is trolling around on giving false info to unsuspecting victims
Old Feb 16, 2011 | 09:36 PM
RedBaronK's Avatar
this is what i thought... i maybe new to a g35 but i knew i wasnt wrong.... thanks for the clarification guys.
Old Feb 17, 2011 | 05:22 PM
giorgios's Avatar
how many mile should they be replaced?
Old Feb 17, 2011 | 05:47 PM
RedBaronK's Avatar
I did mine today at 31k.... I read somewhere its fine to go longer, but I also read that due to the breaking in of the components, the fluids in the car will have metal shavings and its good to flush at 30k first, then 45-60k after that.
My old car died on me cause I never took care of it, so I am paranoid about this one.
Old Feb 18, 2011 | 08:27 PM
jessefrank's Avatar
[quote=RedBaronK;5684002]I did mine today at 31k.... I read somewhere its fine to go longer, but I also read that due to the breaking in of the components, the fluids in the car will have metal shavings and it’s good to flush at 30k first, then 45-60k after that.quote]
Agreed with RedBaronK, although, I'd say stick with the recommended service interval throughout the life of your car.
You may "waste" a little more $ doing fluid changes more often than not, but I, for one, have never had an issue with reliability due to maintenance ("knock on wood").
I've owned several Chevy, Jeep, Mazda, Audi, Nissan and now, Infiniti vehicles. I use top quality, name brand components/fluids and synthetic whenever possible (not always manufacturer approved/recommended) and changed at the lowest manufacturer service schedule; at about 3-4k for oil and usually every 30K for diff/tranny. I'm not a "racer" by any means, but definitely don't baby my vehicles and like to enjoy driving them for whatever they were designed (or built aftermarket, be it off-road or street/track). Since following this mentality, no matter the make, nor quite frankly the name brand component/fluid, as long as the service is done more frequently (within reason) I have not had any issues...even with vehicles over 150K miles and two (Jeep) over the 200-250k mile mark.
Old Feb 19, 2011 | 06:57 AM
gtbigup01's Avatar
^ +1 on that
But...... I don't have anything with 100k on it though.
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
yosip1115
16
Sep 28, 2015 04:14 PM
DRG35R
Sep 16, 2015 05:33 AM
CV35Driver
Sep 15, 2015 05:09 PM
UT G35
Sep 3, 2015 03:58 PM
