iPhone4 mount/charge/wire for audio/video
Old Feb 18, 2011 | 09:58 PM
Sjshore75's Avatar
Does anyone have suggestions or actual experience and success in mounting an iPhone 4 in 07G35x where it also charges and allows you to listen through the car speakers?
Thanks in advanced!
Old Feb 20, 2011 | 10:57 PM
TShepp's Avatar
I bought the Apple brand Composite Video Cord and plugged it into the center console input, I purchased a 12V-USB adapter and plugged the USB from the Apple cord into it. I also did the video lock-out mod so I can watch music videos.
Few examples:
Old Feb 20, 2011 | 11:46 PM
rpm&my_G35's Avatar
Get something like this. I put one in mine a couple years ago. Works great. There are other less expensive similar devices available now as well.
http://www.g35parts.com/G35-iPod-Fac...999u7-ipod.htm
http://www.scosche.com/consumer-tech/product/1667
Old Feb 23, 2011 | 01:44 AM
Sjshore75's Avatar
Thanks for the info guys. But where do you mount your iPhone and I want to be able to keep the wires hidden. There is such little room in the center console I would rather noY have then wrapped up in there...suggestions?
Old Feb 23, 2011 | 08:05 AM
3lpaisa's Avatar
Question
Few examples:
hey how did u do the lock-out mod?? to see videos as u drive?> i tryed doing it looked under saw the little switch the is touched by the ebrake so i bend that metal piece hope it worked it did but i guess it has a speed sensor and that was a head scratch-er lol
Old Feb 23, 2011 | 10:02 AM
rpm&my_G35's Avatar
I drilled a hole (3/8 or 1/2", not sure) in side the console, beside the RCA jacks, and passed the wire through, toward the front so it can be used for my 5th Gen iPod Video or BB Torch.
Initially the mount I made was like this; https://g35driver.com/forums/v36-aud...lip-mount.html
A while ago I removed the flex clip, repainted the metal with PlastiDip and attached a 1sq.in. piece of Velcro. I put some soft loop Velcro on my iPod and anything else I want to attach. It works great and looks clean.
iPhone4 mount/charge/wire for audio/video-img-20110223-00037-2-.jpg
This one shows my Otterbox case attached. I set my BB Torch in it. I didn't like the Otterbox on the phone so I rigged it up for use in the car instead.
iPhone4 mount/charge/wire for audio/video-img-20110223-00036.jpg
Old Feb 24, 2011 | 02:40 AM
arashb's Avatar
Does anyone else also get a high pitch whine with the Apple wires when charging? Or is that just the charger adapter I'm using?
Old Feb 24, 2011 | 07:43 AM
rpm&my_G35's Avatar
The G has a bit of a grounding issue when you use the RCA plugs and have a charger attached at the same time.
Get a Ground Loop Isolator. You can find one at you local electronics store, RadioShack/The Source.
Infinitude
V36 Audio, Video & Electronics
Oct 19, 2008 02:10 PM
hollowch
May 21, 2007 11:03 AM
