going to dealership in the morning, need some info on warranty repairs
Old Feb 24, 2011 | 08:42 PM
samsizzle's Avatar
so basically I am going in to the dealership in the morning because my car shudders 1/10 times when I come to a complete stop.
is this considered a transmission problem? My 08 sedan is certified so that should be covered correct?
also my rubber surrounds on the door are popping out, will they replace this?
lastly, my sun roof surround on the top is cracking, will they replace this and is there a TSB? how should I bring this up
I already got the brake judder, door pulls, and steering wheel replaced, but besides what I posted above, is there any other TSB's out for the 2008 g35 sedan? Just want to get it all done if I can without any hassle.
thanks for your time.
Old Feb 24, 2011 | 11:00 PM
thundercracker's Avatar
if your car is still under warranty, just ask about those things.
if you have time, search for TSB on these forums, there is a link to a tsb website that you can look up all those tsb's and print them out
Old Feb 25, 2011 | 12:14 AM
Anton_Chigurh's Avatar
http://infinitihelp.com/
This should have all the TSBs
That shudder sounds like a transmission problem as a few others (including myself) have felt it
I am actually headed there on Monday for almost the same issue. I came to a stop at a red light today and the car suddenly lurched forward. I never felt that before and it didn't feel normal. Better safe than sorry! They are going to run diagnostic on the transmission
Old Feb 25, 2011 | 02:15 AM
samsizzle's Avatar
thanks guys, found a lot of good ones i'm going to bring up tomorrow:
ITB10-004a
2007-2010 INFINITI G35 SEDAN AND G37 SEDAN, COUPE, CONVERTIBLE; A/T SHIFTER VINYL BOOT COMING OFF
TITB07-034
2007 INFINITI G35 SEDAN; DOOR WEATHERSTRIP LOOSE
The front or rear door weatherstrip has pulled out or loose a little or a lot
ITB07-032
2005-2008 INFINITI G35 SEDAN AND FX; SUNROOF LID SEAL
The sunroof lid seal is not sealing correctly.
ITB09-038
VARIOUS INFINITI MODELS; SUNROOF WIND NOISE
A wind noise is coming from the sunroof glass area.
one thing that wasn't on there but bother's me to no end is that my driver side tweeter area has an annoying buzzing sound when ever I play a bass heavy song. Would they check out/add insulation for free if there is no TSB?
here is a video I took:
Old Feb 25, 2011 | 10:11 AM
if that judder is not from your brakes, it could be that your tires need balancing. i reported that judder as i was coming to a stop too, and they did the tsb brake fix, and also balanced my tires.
i was hoping they would clean my throttle bodies too, to save me time, since i've read that dirty TB's cause rough acceleration. i guess i'll have to do the TB's myself. there is a great DIY about that on here somewhere...
as for your tweeter rattles, ask them about it. if you are using a factory stereo, they should be willing to at least look at the problem.
g'luck
Old Feb 25, 2011 | 02:02 PM
kool_yaar's Avatar
if youre still under warranty and you can "replicate" the problem in front of them then they are obligated to check it out under warranty and try to fix it. Should be a quick cheap fix by adding some insulation back there.
Old Feb 25, 2011 | 03:54 PM
samsizzle's Avatar
just got back guys, here are the results:
*resealed the rubber seals on the doors
*fixed the shifter **** material from coming off.
*found that my driver side subwoofer was faulty so they ordered a new one
*ordered seals for back windows because air came in
*applied an update to car for the idle
what I'm going to bring up when I go back,
- idle update didnt do anything, car still shudders at stop!
- sunroof lining is cracked, and would like to replace it
thanks for all the help guys, good luck to you aswell
Old Feb 25, 2011 | 06:22 PM
G3507Tech's Avatar
I have no idea about TSB,what are they? Do I need one to fix the issue under warranty?
I have couple of issues but all dealers are not helping under warranty.
I have the same problem sunroof lining is cracked but no luck and the rubber seals on the doors had cuts and coming off and also shift **** peeling off.
Please help how can I get them fixed under warranty.
Old Feb 25, 2011 | 07:53 PM
samsizzle's Avatar
go to the infiniti help site and bring those numbers of the TSB fixes to them, they should fix them I would think?
Old Feb 26, 2011 | 09:10 AM
G3507Tech's Avatar
I searched the 'TITB07-034' in the forum infinitihelp.com but could not find anything. How to search the above TSB?
Old Feb 26, 2011 | 11:13 PM
treacherous's Avatar
20 Year Member
G35x
Link
Old Feb 27, 2011 | 09:57 PM
G3507Tech's Avatar
Originally Posted by treacherous
Now I can look up all the TSB.Thank you!
Old Feb 27, 2011 | 10:06 PM
tbarney's Avatar
On the idle thing: Ours started "dipping" and causing the shudder after we had the ecu updated last year. Took it back after a few months, but my first request to fix the problem was basically ignored with a "could not duplicate."
The last time I went in, I rode around with the mechanic until it happened, and he said "Yup, that's not normal." (The guy looked like Santa in the off-season, btw.)
They did some diagnostics, didn't like what they were seeing with the ignition timing, and end up replacing both mass air sensors. (BTW, they said they would only do it if I would pay for new air filters, because mine had almost 20k on them and were pretty dirty. $77 later...)
I also got a lecture about using the "right" gasoline. Apparently, around here, Shell isn't good enough, and I should only be buying Chevron or QuikTrip.
Right.
They also said they did the "idle air learn" procedure.
So when I got it back, I found the problem was better, but not gone.
I pulled the throttle bodies, and boy were they black and grungy. Cleaned those well, using the instructions found here, and ran a bottle of Techron through the next tank of gas.
(Also found that the short hose from the crankcase to the air intake, on the drivers side of the engine, was disconnected, so I made sure it was on correctly when I put the TB back. Couldn't tell you if that hose has been off since the last visit over 11k miles ago, or if they did it that day when replacing the mass air sensors.)
I do believe the idle problem is now greatly diminished, if not completely gone.
I suspect it's a combination of clean air filters, clean throttle bodies, and possibly the idle air procedure. As Santa explained, these cars are very finely tuned to be able to get the power they do, as efficiently as they do. Doesn't take much to upset the balance.
Not saying my experience will be the same for everybody, just providing some data points.
Old Feb 27, 2011 | 11:38 PM
samsizzle's Avatar
^awesome information!! if they cannot fix it, the first thing I will do is clean the throttle bodies. thank you for the informative post
Old Feb 28, 2011 | 11:22 AM
Dcrow's Avatar
Right.
Hey tbarney- question for you since we are both in Atlanta. Where do you take your car for service? I bought my car in October and the original warranty is up in a coupe months so I want to have a couple things looked at before then. Thanks
