18 inch wheels installed on a G35x
Old Mar 2, 2011 | 11:47 PM
jimboG35x's Avatar
I was thinking about getting the vossen vv-083 staggerd rims 20 inch.So ur saying im gona mess up my awd system by getting these rims...
Old Mar 3, 2011 | 07:20 AM
soundmike's Avatar
Again, as long as your overall rolling diameter equals that of your OEM set-up, you'll be fine.
Old Mar 3, 2011 | 10:28 AM
jimboG35x's Avatar
How would I achieve that if stock is 18 inch and my aftermarket is 20 inch
Old Mar 3, 2011 | 11:04 AM
AesonVirus's Avatar
Ok... this is not that confusing......
Just Make Sure All Four Corners Have The Same Rolling Diameter
If your front tires can make one full rotation sooner than the tires on the back.... that does cause risk to your AWD system.
The size you choose has nothing to do with it. You can go build a donk if you want... just make sure all four are the same outside demensions (or damn close)
Old Mar 3, 2011 | 11:17 AM
Greekboy115's Avatar
Maybe some visual aids will help out..
In this case the diameter is the size of the wheels and tires together. The diameter of the wheels on the front and the rear would need to equal in order to prevent any damage to your AWD system. The calculator that Scott (AesonVirus) provided helps you figure out that amount via how the aftermarket wheels will affect the speedo. What you are trying to figure out is the right combo of wheels and tires on the front and rear so that they will give you the same result i.e. mph.
If properly done the circumference will be equal and won't affect your AWD.
Old Mar 3, 2011 | 11:55 AM
djfarhan's Avatar
i need me to get some wheels...;-/
Old Mar 3, 2011 | 01:24 PM
soundmike's Avatar
By changing tire sizes.
Old Mar 3, 2011 | 02:28 PM
The-Dream's Avatar
You're not going to get the exact same sizes for front and rear for a staggered set-up. You just have to be as close as possible.
Old Mar 3, 2011 | 05:16 PM
Triton3.5's Avatar
Originally Posted by AesonVirus
I like this calculator....
http://www.autos.ca/tools/tirecalc/tirecalc.htm
It tells you everything, including how far of your speedo will be.
My wheels are MRR GT-1's in Hyper Silver
They come in Black or Chrome as well.
Hey Scott,, was wondering how much those wheels weighed,, if you don't mind me asking...
Old Mar 3, 2011 | 08:32 PM
jimboG35x's Avatar
the back rims r just a little wider not taller,so ill just get the same size tires front and back but the back rims will be a little wider thats it.I dont think a wider rim would effect the rotation or i might be wrong..
Old Mar 3, 2011 | 08:52 PM
AesonVirus's Avatar
Give me the weekend and I'll let you know.
My dealer fvcked one of my wheels up so I have a brand new one sitting in my garage.
I'll weigh it and let you know.
Old Mar 6, 2011 | 10:36 AM
Triton3.5's Avatar
thx man... really like the look of those....
Old Mar 10, 2011 | 06:07 AM
jimboG35x's Avatar
has anyone put 22 on there infiniti and was there any rubbing
Old Mar 10, 2011 | 07:52 AM
soundmike's Avatar
^ As long as you have the proper profile and width tires, width and offset wheels, you should not experience any type of rubbing whatsoever.
Old Mar 10, 2011 | 09:26 AM
  #30
djfarhan's Avatar
dont know if 22s will look good though
