need help asap.
Old Mar 13, 2011 | 02:40 PM
RedBaronK's Avatar
need help asap.
Does anyone have a guide or a video on how to remove the intakes so that I can clean the throttle body on a 2nd gen? Got the engine cover off, but I realized from the diy for tb cleaning there's no guide on how to remove the intake... I don't want to screw anything up
Old Mar 13, 2011 | 02:59 PM
kool_yaar's Avatar
its very easy... do at your own risk
1) Unbolt the solitary bolts on both intake boxes near the fenders on both sides (clearly visbile)
2) Unscrew the clamp on the TB end of the intake tube
3) Unplug the MAF wire carefully so you dont damage the connector and remove from the intake tube clip
4) Loosen the tube from the TB by pulling away from the TB
5) Pull the entire intake box upwards with some force yet being a bit cautious
thats its really, someone chime in if im missing anything.
Old Mar 13, 2011 | 03:34 PM
RedBaronK's Avatar
I had to stop for now. When I saw the MAF and all those wires attached to the intake, it made me crap my pants. Trying to find a guide with pics and step by step instructions. Thanks for ur rapid response, but I don't even know what a solitary bolt is lol....
The thing that I noticed in the diy guide videos was that on the first gen, intake can be removed by itself, but on the 2nd gen the whole intake including the filter box needs to be pulled out in order to access the tb? Am I right?
I noticed that there is a small hose with clamps attached that run between each intakes..... what do I do with these?
Old Mar 13, 2011 | 05:47 PM
RemmyZero's Avatar
i didn't take pics when i did mine but ill try taking some pics when i get home tonight and photo shop some arrows in for you. it's fairly easy as i recall....
Old Mar 13, 2011 | 05:51 PM
RedBaronK's Avatar
Thx, any help would be appreciated since all I could find was info on 1st gens only
Old Mar 19, 2011 | 12:51 AM
Mr. TG35S's Avatar
There is a DIY here somewhere. I just did this. Just undo the hose clamps and you won't have to take out the air boxes. For the passenger side, I just undid the bolt holding down the small hose that transverses the engine and the whole thing just lifted out of the way. For the driver's side, I undid a hose clamp on the hose that attaches to the intake and lifted the whole intake out of the way. I do recommend replacing the throttle body gaskets ($8 each and worth replacing).
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
_evilMonkey_
2nd Gen (V36) Sedan
Nov 22, 2015 06:21 PM
esy
Sep 1, 2015 09:10 PM
Ray Feta
Aug 20, 2015 08:46 PM
poker_lamina
Aug 14, 2015 12:57 AM
