What should I do with my brakes.
By the way, anyone want to comment on whether or not they put any grease on the sliders or ends of the brake pads where they slide? Dealership told me they put a little bit on the ends of the pad where they contact the slides to minimize brake squeal but the shop manual says to only apply grease to the slidesif you are replacing them.
I'm getting a bit of brake squeal and not sure if it is from bedding in process or if maybe my slides need to be replaced or lubed better.
Thoughts?
Thoughts?
I put brake grease to the tabs. Others say you can lube the back of the pads too although I usually use CRC brake disc quiet there. Also, make sure you clean and re-lube the caliper pins.
Thanks for the insights. I did also do the caliper pins so no worries there. I did the tabs but not the back of the pads. I might check out the CRC brake quiet if they don't quiet down soon (still getting bedded in).
