Need some help: about washer fluid light
Old Apr 6, 2011 | 07:11 AM
johnnyzee's Avatar
Hi guys,
I hope someone can help me out here.
One night, the "washer fluid low" warning message popped up on the dash. I figured, cool, no biggie, throw some in when i get home.
It wasn't too low in reeality but i topped it off and thought all was well.
Then, ever since, every time I start the car, that same warning message appears. I checked the canister under the hood many times to determine if i had a leak but it was as full as it can be every time.
Is there a reset for this warning message or am I looking at a different issue.
Thanks for any input you can give
Old Apr 6, 2011 | 09:18 AM
BionicG35's Avatar
it could possibly be a bad fluid level sensor
Old Apr 6, 2011 | 11:08 AM
jaeisber's Avatar
Yeah, sounds like a bad sensor. I have had a few go bad in other cars. Not much you can do but have it replaced.
Old Apr 6, 2011 | 12:23 PM
johnnyzee's Avatar
Guess so, hopefully it might still be under warranty.
Old Apr 6, 2011 | 12:25 PM
jaeisber's Avatar
It should be. How many miles do you have?
Old Apr 6, 2011 | 05:12 PM
johnnyzee's Avatar
Just checked, I have 48k kms (not sure miles) and covered up to 4yr 100k. Ill let the dealer worry about what's wrong with the sensor.
Old Apr 6, 2011 | 09:45 PM
Mr.GEE's Avatar
20 Year Member
Could be just a loose connector at the reservoir.
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
jbmw002
Drivetrain
Aug 27, 2015 03:01 PM
linedr89
Aug 17, 2015 05:11 PM
underworld
Aug 6, 2015 01:36 PM
itschuckster
Jul 25, 2015 08:07 AM
