Clearance/Parking Lights will not work?
Old Apr 23, 2011 | 03:15 PM
jnewk1981's Avatar
I've been having problems for about the past 2 weeks. I bought white LED's for what my Infiniti's owners manual calls clearance lights on my 2007 G35x. When I installed them one never lit up and the other stayed on for about an hour or two and then would not come back on. I purchased new bulbs from a different seller and now niether one of them will work or any other bulbs for that matter(License plate bulbs) Bulbs #2827 and #168 are the same wedge bulbs correct? There's no way that I received #168 bulbs that will not work on a recomended #2827 right? Could this be a blown fuse and if so which ones should I check? When are these clearance lights suppose to be on? Thanks
Old Apr 25, 2011 | 12:54 AM
jnewk1981's Avatar
Anything? Please help... Thanks!
Old Apr 25, 2011 | 02:27 AM
kool_yaar's Avatar
i believe the parking leds are 194/168 the thing with leds is that they must have right polarity when installed, if you flip the bulb it should work if the bulb and harness is fine. If the led is installed correctly then it could be a fuse in foot well on the driver side, the cover has guide of which fuse is for what to help you.
Old Aug 21, 2011 | 12:59 PM
cnugs127's Avatar
Can anyone tell me if there was a resolution to this problem? i am experiencing the exact same thing. i took out the LED's and replaced them with the stock lights and they still don't turn on. i checked the fuses near the car battery as well as the fuse box near the clutch pedal and i didn't see a fuse for these lights. Can someone chime in with their thoughts? Thanks
Old Aug 21, 2011 | 07:42 PM
jnewk1981's Avatar
Nothing!
No replies and my lights still don't work... Some help would really be appreciated! Thanks!
Old Aug 21, 2011 | 09:32 PM
GXXXV X's Avatar
i have also tried several different leds and all of them went out within a few weeks.... have you tried going back to the oem bulbs to see if the outlet still works?
Old Aug 22, 2011 | 01:08 AM
cnugs127's Avatar
just tried today with the oem bulbs and no bueno
Old Oct 19, 2011 | 01:57 AM
cnugs127's Avatar
bump
Old Oct 19, 2011 | 02:52 AM
vqsmile's Avatar
Have you ever verified that there's power to the socket?
Old Oct 19, 2011 | 07:02 PM
GXXXV X's Avatar
After my leds kept going out I just went back to oem and they work perfectly...
Old Oct 21, 2011 | 01:30 AM
cnugs127's Avatar
There's no power going to it so I figured I blew a fuse, but I can"t find the fuse for these lights.
Old Aug 28, 2012 | 09:29 AM
Shift1982's Avatar
Theres a "clearance" fuse in the bcm (fuse box) near the battery.. Should work
Old Sep 7, 2012 | 01:11 PM
shortchaz's Avatar
Got a pic of the fuse location or what else it's called? I saw nothing in either of my fuse boxes on my 08 that would relate to these lights.
Old Jun 26, 2014 | 08:26 AM
suby01's Avatar
bump im just having the same exact issue. any resolution guys?
Old Jul 31, 2014 | 03:39 AM
TEX4S's Avatar
I am now having the same problems. Both of the clearance lights are not working.
I replaced one with a 6000K LED - but nothing. I noticed the original was amber and it was in fact burnt out (filament was severed). When the 1st didnt work, I did not mess with removing 2nd wheel. I will do this again tomorrow and switch the bulb to see if polarity was the problem. I am also going to check the "clearance" fuse to see if something is up there (I'll just replace it regardless) - but since I found this thread - I will post tomorrow after I do replace the bulbs so it may help others. When do these lights normally come on ?
Clearance from what ?
Mry
Mar 3, 2023 01:03 AM
mike730
Jan 12, 2018 04:25 PM
myaso
Lighting
Jul 22, 2015 10:34 PM
attarday
Jul 15, 2015 04:03 PM
