Offset Question!
Old May 13, 2011 | 09:08 PM
GXXXV X's Avatar
Cool Offset Question!
hi i know offsets have been discussed before but i couldnt find it quickly enough so ya sorry about spamming/reposting
Question: I am deciding on 20x8.5 wheels but the ones i want only come in offsets of either 35 or 45. which one should i choose? would it make a difference if i want to lower my car as well? Pics are super helpful if you have either offset! Thanks!
Old May 13, 2011 | 09:22 PM
kool_yaar's Avatar
any and all info you can handle about offsets here: member's wheel setups plus you can click on their names with CTRL to see pics of their setups. (click on suspension word file)
Lower the offset the more aggressive(sticking out) the wheels, 35 should be better imo, droppin make a difference of course as it tuck the wheels a bit allowing for a more aggressive offset if required.
Seems as if this guy has 20 x 8.5 35mm front as listed in the doc
enjoy.
Old May 13, 2011 | 09:26 PM
GXXXV X's Avatar
awesome, thanks! def going wit da 35 then!!
Old May 14, 2011 | 06:24 AM
bluedevils95's Avatar
stock off set is +35 all around. On my car i am running +27 and had to make the car fit the wheels.
Old May 14, 2011 | 08:28 AM
soundmike's Avatar
^ Actually, i believe the stock offsets for the S are +45f/+50r
8.5" wide wheels at +35 is a nice conservative, yet positively noticeable, change.
Old May 14, 2011 | 11:01 AM
GXXXV X's Avatar
ok cool would 35 mm offset need spacers at all?
Old May 14, 2011 | 11:25 AM
soundmike's Avatar
With the minimal drop i have, i was happy with the +35's (albeit, in 19's). Not too tucked in to look odd, but not poking out either to where i had rubbing or clearance problems.
Old May 14, 2011 | 11:49 AM
tpc303's Avatar
I would say if your going drop it run +35, but you may want to add 10mm spacers all around. Check out ChinkyChoy's ride he's +25 all around and it looks real nice.
Old May 14, 2011 | 03:33 PM
makeinu0's Avatar
I would say try the +35 first and then ltr go with spacers to adjust
Old May 15, 2011 | 01:19 PM
GXXXV X's Avatar
Okay that sounds like the best plan, think that's what I'll do, gonna drop an inch out two first though
Fire0nic3
Aug 31, 2015 03:18 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
reaper76
Aug 5, 2015 10:13 AM
