Help! Did I just F up my transmission?!!
Old May 15, 2011 | 05:20 PM
machochino's Avatar
So I went to my trusty mechanic to get transmission flushed and brought 12qts of matic S. I also got 2qts of matic D for the transfer case. I left to get some cash and when I came back I found he put all 14qts into the flush machine!!!
Please tell me this won't cause an issue with my tranny.
I'm thinking he poured the 2qts of matic D first and then the other 12qts. Since we flushed 14qts it might have flushed out the matic D. In the end I even had to top off with another bottle of matic S. I figured since matic D is also ATF I should be ok but I'm not sure..
Old May 15, 2011 | 05:40 PM
Infiniti Chica's Avatar
Both bottle are clearly ATF. Matic J is the same as Matic D-- you should be fine.
Nissan changed the formula slightly and relabeled the bottle. In the end, however, if we're wrong,, the responsibility is with him since he was the mechanic.
Old May 15, 2011 | 06:03 PM
kool_yaar's Avatar
well i know for sure that matic J and S are exactly the same and just relabeled once AM companies "decoded" the mixture and started making cheaper fluid which was guaranteed to be compatible with Matic D applications, im guessing it was the same issue with D
Old May 15, 2011 | 07:30 PM
machochino's Avatar
whew! Its funny you say that since matic S costs several dollars more than matic D. Anyway, I was hoping its all the similar ATF. The labels on the bottles I got look nothing like the ones above.
Old May 15, 2011 | 07:33 PM
machochino's Avatar
BTW, I read a lot of threads about drain/refill vs full flush. In my opinion, after going through my first flush today using drain/refills on all my other previous cars... flushing seems a much better method.. if done correctly!
Old May 15, 2011 | 07:52 PM
thescreensavers's Avatar
Mr.202?
Matic S is has more synthetic properties then J.
And hopefully not, Go smack your shop for not reading the warnings plastered all over the manual and engine bays.
Also 14 quarts is not enough to get out all of the old fluid, But depending on how he did it, you might have little matic D in their but I would not gamble on a tranny, they are expensive.
Old May 17, 2011 | 11:33 PM
machochino's Avatar
So what are you saying screensaver... is I need to reflush my tranny with matic S? That is more $$$
Old May 17, 2011 | 11:45 PM
kennymo's Avatar
you can pour 100 qts into the flush machine. it will still be fine the way flush machines work is it only puts as much fluid in as the amount that came out.
Old May 29, 2011 | 02:41 PM
machochino's Avatar
Kenny, I think that is obvious. I was stating that I think the tranny holds 11ish qts of oil and if you flush 14-16 qts, I am hoping the first new 2-3 qts have also been flushed out with the old 11ish qts. In other words, the machine should of flushed out the Matic D or at least most of it that shouldn't be in there.
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
g.spot
May 9, 2016 10:54 PM
f22raptor
Mar 18, 2016 08:50 AM
Row2k
Drivetrain
Dec 27, 2015 04:08 PM
Usman Ali
Sep 22, 2015 06:59 AM
