Advice Needed: 07 or 08 G35-S - which to buy?
Old May 17, 2011 | 07:45 PM
cipper's Avatar
Newbie so easy on me.
Which should I buy: (1) 2007 G35S (Sport) Sedan or (2) 2008 G35XS (sport) Sedan?
As I understand it, the "07" is only RWD, comes with different size rear and front tires and the "08" version of the sport comes both AWD and RWD (after a certain speed). I believe the "08" has the same size rear/front tires.
In driving both, the only major difference is the exhaust sound on the "07", sounds a little like the coup. And of course the RWR fun.
So.....looking for your advice, is it worth dropping an additional $3k for the "08"?
Any other advice would be welcomed.
Old May 17, 2011 | 07:49 PM
mishmosh's Avatar
If you could use the AWD, then get it. Otherwise, I would get the 2007 if it is still under warranty--if not, go for the 2008. There were a lot of issues with the 2007. I have been to the Dealer more times than I'd would like for my 2007.
Old May 17, 2011 | 08:07 PM
vqsmile's Avatar
Yeah, if you don't particularly have a need for an AWD car, I see no need to get one; more moving parts, more to maintain, more to break, etc. etc.
FWIW, my '07 has been pretty solid for me so far (48k miles), no issues other than brake judder.
Old May 17, 2011 | 08:21 PM
Hotdawwgman's Avatar
I wish I had an X.... I think that would be fun!
Old May 17, 2011 | 08:30 PM
J2S2M's Avatar
I would look for an 08 S sedan and not an xS sedan. Keep in mind that X's are limited to even less aftermarket support than a RWD sedan. That's the main reason why I personally prefer RWD over AWD. I guess depending on where you live, AWD might come in more handy / practical for you. In the end, do whatever makes U happy bro. GL with your decision.
Old May 17, 2011 | 08:50 PM
da mayor's Avatar
i love my 2007 G35 S..... too bad it's going to a new owner soon
Old May 17, 2011 | 09:07 PM
Anton_Chigurh's Avatar
What issues? I know there are some issues with the 07..but a lot? Shudder is the really only big one i can think of mechanical wise
Old May 17, 2011 | 09:43 PM
cbrseadude's Avatar
Remember the AWD system isnt designed with performance in mind, more all weather than anything. So if its performance your looking for, go RWD.
Old May 17, 2011 | 09:47 PM
cipper's Avatar
Thanks guys - I'll let you know what I end up getting.
Old May 17, 2011 | 09:57 PM
DFWG35driver's Avatar
Only problem I have had with my 07 is the cam shaft sensors both had to be replaced.
Old May 18, 2011 | 10:30 AM
Seal89's Avatar
what about performance in rain or snow? AWD will always make a superior car overall its more blalanced, more and more supercars are now coming AWD (Veyron, Lamborghini, etc..) just because 4 wheels is obviously better than 2. The only point is yes it can be fun to do donut in the winter with a RWD.
Old May 18, 2011 | 11:05 AM
cbrseadude's Avatar
Well sure it will give superior traction in rain or snow, but its not designed for dry performance like a lambo or gtr, its not capable of those kinda things. I just want the guy to have all the info he can get.
Old May 18, 2011 | 11:15 AM
soundmike's Avatar
Considering ATESSA-ETS was originally used on the R32, and has made the rounds in development since, that it's fair to say that it does have performance characteristics.
Old May 18, 2011 | 11:33 AM
soltis007's Avatar
Same year & miles as VQsmile...Only issue I've had is brade judder otherwise the cars been perfect. (07, 48k)
Too, I live in the snow belt. Minny to be specific. I choose RWD because I knew that snow tires would be the way I was going to go. Yes its more effort when the snow begins / ends, but I didn't want the slightly lower mpg the awd gives you, the extra weight, and have to deal with a set of tires that could do it "all".
Too, this way my summer rims stay perfectly clean, and my winter rims get the chemicals & salt...
My Blizzak LM-60's are incredible in the snow as well...never had any issues either.
There's advantages either way you go. Some people might want what I just spun as not something I desired, a tire that can do it all, and no desire whatsoever to change out rims...all personal preference
Old May 18, 2011 | 12:24 PM
arok5's Avatar
Hey, I have had some shudder issues with mine. Thought it might go away, but it seems it's a daily issue now. Any ideas on what to do? Thanks!!!
