Cracks in knuckle?
Old May 21, 2011 | 12:02 PM
soundmike's Avatar
Cracks in knuckle?
Has anyone ever encountered this before? I just noticed this today, it seems to be mostly cosmetic but you never know.
I don't recall ever hitting any ridiculous bump on this side of the car, the passenger side (which i did hit a big bump, enough to bend my forged rim a while back) was fine.
Old May 21, 2011 | 12:23 PM
vqsmile's Avatar
I can't quite tell for sure from that pic, but my guess is that they're just casting marks Mike.
Old May 21, 2011 | 02:17 PM
soundmike's Avatar
Some areas of the crack are somewhat raised (enough to scrape a few layers off my gloves), so you may be on to something there. I hope that's the case though, and nothing more serious.
Thanks!
Old May 21, 2011 | 02:44 PM
sdonabo's Avatar
it looks like that part has a finish because its also cracking below the circle.
i would have some 1 take a look at it just in case
Old May 21, 2011 | 02:53 PM
vqsmile's Avatar
Thanks!
A easy check may be to hit that area with a fine sandpaper and then quickly buff it. If the cracks are present once you've gotten down below the outer surface, then you've got something to be concerned about. Of course once you get a little patch of polished aluminum you're just gonna make the rest look bad
Old May 23, 2011 | 10:50 AM
InfinitJazz's Avatar
Almost every cast piece that I've come across on any car, mine included, that aren't visible normally, have those same casting marks. I have them on all my control arms as well, nothing to worry about, they're not cracks.
DRG35R
Jan 31, 2016 07:14 AM
Batfinity
Lights
Sep 27, 2015 12:29 AM
Atwork
Intake & Exhaust
Sep 20, 2015 03:36 AM
