what kinda oil do you like?
Old May 24, 2011 | 05:51 AM
  #31
harp00n's Avatar
what about Motul 8100 Eco-Energy? I used it for 50K miles, and it seems to work ok with the vq35hr and I want to use it more...
though it seems like it wears a lot of iron and aluminium?
Old May 24, 2011 | 09:46 AM
  #32
JDMPenn's Avatar
Anyone tried going 15k miles with their Mobil 1 Extended Performance?
Old May 24, 2011 | 09:55 AM
  #33
herrschaft's Avatar
Why would you want to? Long term effects on the engine may have you wishing you've changed the oil at normal intervals.
Old May 24, 2011 | 09:56 AM
  #34
g35xdriver's Avatar
g35x
the free kind, from the dealer, every 3750.
Old May 24, 2011 | 01:12 PM
  #35
typhus's Avatar
Listen, everyone is going to have a different opinion and bias as far as which oil is best,,,
whatever, when you get down to it, its still all oil. Lets try and keep it simple, and the most important aspect concerning your engines lubrication is the filtration... plain and simple.
Napa Gold filters are the trick and will make even a mid grade oils (valvoline) viscosity outlast even a pure high grade full synthetic, and I know first hand since I work for Southwest research that tests all engine performance products and applications.
Filtration is the key, and although some lubricants will out-perform others, to keep it simple, oil is oil,,,, and filtration is where the consumer will benefit the most.. your oil filter IMO is by a wide margin the most beneficial aspect when considering the investment.
Old May 24, 2011 | 04:41 PM
  #36
gtbigup01's Avatar
Here's some info on filters. I'm not endorsing either since I've never used them however, starting this weekend Puralator One (orange one) will be the filter of choice for my 07 Yamaha FZ1. Not sure if one fits the G, if it does, then I switching that as well. So much for more expensive = better product. IMO @ $3.81 you cant beat the WM ST filters. You decide
http://motorcycleinfo.calsci.com/FilterStudy.html
Old May 24, 2011 | 04:59 PM
  #37
vqsmile's Avatar
^^ lol, it's sad but true that our filters are so small that their sizes do turn up now and then in the context of motorcycle applications
Old May 24, 2011 | 06:56 PM
  #38
djfarhan's Avatar
this kind:
Old May 27, 2011 | 04:10 AM
  #39
thescreensavers's Avatar
Mr.202?
Originally Posted by faiz23
Yes this is somewhat true but really depends on the quality of the synthetic. If you are using like MOTUL which is like a group iv/v synthetic then you could easily go 5000 miles with a k&n filter with no issues.
Some bad info their, just because an oil is a certain group, does not mean it can be used longer. Castrol Edge has a lot of additive this oil is mostly Group III. A reason Castol edge was made for, is for extending drain intervals. It has lots of additive(TBN). TBN is not the only thing for long intervals, you need to make sure wear levels are low and there still is a good amount of TBN.
Oil weather its Group over 9000 or group III does not mean one will run better then the other.
If you want to run extended intervals get a UOA with TBN count.
Old May 27, 2011 | 04:20 AM
  #40
lsmooth81's Avatar
Royal purple and K&N filter.
Old May 27, 2011 | 11:37 AM
  #41
vqsmile's Avatar
Oh goodie, another oil debate thread
f22raptor
Mar 18, 2016 08:50 AM
prinny
Nov 22, 2015 11:07 PM
mbe32
Nov 13, 2015 11:09 PM
9tray turbo
Sep 29, 2015 10:22 PM
