CLucth question.
Old May 23, 2011 | 06:30 PM
Fendi35's Avatar
CLucth question.
As many of you guys know i had a problem with my clutch. Well i ended up putting in ACT clutch and flywheel, the clutch is considered stage 1
So its been a couple weeks and the chattering sound is slowly going away.
Mainly chatters in 1st and 2nd gear.
Now my question is when the clutch was first put in the chattering noise was really loud and the clutch engaged at a much lower level...(closer to the floor)
Now with the chattering noise being almost gone it engages higher,... almost if not at the same point as the stock one.
But every gear its a lot better then the stock one was, meaning it grips better, and the car feels faster.
Should i be worried or is this suppose to happen.....
Old May 23, 2011 | 10:52 PM
kool_yaar's Avatar
sounds like its normal, the clutch actually takes a while to "break-in" to make shifting easier, sounds like thats what youre experiencing but of course i cant say for sure just from what you tell me... also with AM clutch's on our G's the chatter will always be worse than OEM so be prepared for that...
AT23
Sep 15, 2015 07:44 PM
Terry_G35
Sep 10, 2015 08:17 PM
Fire0nic3
Aug 31, 2015 03:18 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
