Connecting Android phone to 2008 G35?
Old Jul 30, 2015 | 10:59 AM
crazy_g35s's Avatar
what cables did you buy?
Old Jul 31, 2015 | 11:05 AM
g35xdriver's Avatar
g35x
Originally Posted by speedracerg35
There is no a2dp on 08-09 models. I stream audio through kinivo bluetooth adapter. You will need a 3.5 plug to rca adapter into the connections in the glovebox. It's all on Amazon for less than $40. The sound quality is better than the factory iphone cable and the phone calls come though the factory bluetooth. Everything is plug and play and is contained completely in the glovebox. You can't use the steering wheel controls for choosing music, but I use Siri to select music.
I'm sure that works great and all, but sound quality better than the factory cable, have a hard time believing that
Old Jul 31, 2015 | 03:12 PM
mrclowny's Avatar
From a suggestion of another user on a different post, I bought the following. The sound quality is surprisingly good.. I haven't used the factory cable in a bit as I switched to Android, but I can't really tell the difference in sound. Plus, the convenience is awesome!
I use it on my 08 G with my Samsung Note Edge.
http://amzn.com/B00GX71GNO
http://amzn.com/B0042B9U8Q
http://amzn.com/B000I963XQ
Old Aug 7, 2015 | 11:23 PM
shepscrook's Avatar
I am curious about this as well. I tried connecting my LG G4 to my 08 G35xS but the car would not detect the phone.
My other plan is to connect a chromecast to the auxiliary ports of the car so I can cast Google Maps for up to date GPS maps from my phone.
But I was hoping to get my phone to work with the built in car phone.
Old Aug 24, 2015 | 12:31 AM
shepscrook's Avatar
This failed sadly.
Old Oct 4, 2017 | 02:22 AM
ellexir20's Avatar
Currently am using the viseeusa 1000 model plug to my 30 pin cable in my car. Wireless streaming works very clear and excellent.
Old Oct 4, 2017 | 01:20 PM
4daluv's Avatar
Did you have to hook up anything else? Cable Jive or any other power source. From I've been reading u have to have some kind of power for this to work ,....
FOLLOWING
Old Oct 5, 2017 | 01:13 AM
ellexir20's Avatar
FOLLOWING
So far mine is only connected to my 30 pin cable although it takes time to power on but I am able to use it. I also read that some buy power converter in order for it to work.
Old Mar 9, 2020 | 08:40 PM
Stickyz's Avatar
G35X S
I needed to buy this converter. It gives power to actual Bluetooth device. So from the 30 pin you plug in this adapter, in the adapter you will plug in a micro usb on the side for power, and then the blue tooth device plugs into the adapter. For whatever reason the car does not give the Bluetooth device enough power alone so that is what this does.
Xtenzi Aftermarket Replacement 12v to 5v Charging Converter Adapter Compatible with Select iPod's
Amazon Amazon
Old Mar 12, 2020 | 12:32 PM
Joenavy85's Avatar
G35x Base
I'm using a QGeeM USB Type-C to HDMI adapter (from Amazon) and a WavLink HDMI to RCA adapter from the local electronics store with my Galaxy S8. Works decently well, I run the App that 909 runs on his tablet, it's called Car Launcher Agama. it allows me to run Pandora in the background and keep the "Home Screen". Only downside is I currently use a small USB mouse to control it, I need to figure out some sort of touchpad to use.
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
crazy_g35s
Jul 20, 2015 02:30 PM
newbdriver01
Jul 15, 2015 06:10 PM
