Offset Double Check
Offset Double Check
Putting in my wheel order within the month, just want to get some outside opinions on my size choice before pulling the trigger. After much thread trolling and scoping out pics and offsets, I have decided on these numbers:
20x9 +25
20x10.5 +40
Dropped on eibachs. Just looking to be flush and filled out. Not trying to do anything toooo aggresive that I have to worry about all the time.
I should also add looking at these tire sizes as they retain the original diameter
F: 245/35/20
R: 275/30/20
Thanks for your input.
20x9 +25
20x10.5 +40
F: 245/35/20
R: 275/30/20
not quite sure where you are going with this one as that isnt the stock numbers and I will be running a staggered setup so uniform offsets wont quite cut it
are you saying that those offsets will poke out a little too much to stay in spec? and does this mean i need to purchase camber arms as well? i was hoping to avoid it.
as for the wheels i believe im going with the 360forged concave mesh. with the price of those wheels I need to get the offset right the first time haha
You better off checking the wheel and tire thread! A lot more info and pictures! These are my wheels F8.5x19 +35 R9.5x19 +45 5mm spacers all around! I think your numbers sound pretty good!
You probably better off checking this thread! More pictures!!
https://g35driver.com/forums/media-s...rket-rims.html
20x9 +25
20x10.5 +40
F: 245/35/20
R: 275/30/20
20x9 +25
20x10.5 +40
F: 245/35/20
R: 275/30/20
Lol I'm on 285/30/20 it's not THAT bad. At times yeah it sucks but unless you're constantly driving in/around potholes it's not terrible
