my car's rear bumper got few scratches, but i had never experiences with those scratches. has any good recommend? (saving money method)
thanks.
thanks.
G35SedanGrn
close
- Join DateFeb 2010
- LocationBay Area 925
iTrader Positive Feedback100
iTrader Feedback Score(17)
Liked:135 Times in 114 Posts
Depends on the scratches...post pics?
Wet sanding and or polishes...or clear coat pen to fill in the scratch. Take a pic we can't help u without it
pic, maybe if you posted in the detailing section you will have better luck.
Megs Scratch X...rub your fingernail on the scratch...if it gets stuck in it (Deep scratch through the clearcoat) then you will have to live with it (thats the cheap method).
vqsmile
close
- Join DateOct 2010
- LocationSF bayarea (925)
iTrader Feedback Score(1)
Liked:427 Times in 368 Posts
what the .... ?
Originally Posted by LakeShore_Slate
pic, maybe if you posted in the detailing section you will have better luck.Megs Scratch X...rub your fingernail on the scratch...if it gets stuck in it (Deep scratch through the clearcoat) then you will have to live with it (thats the cheap method).
He can fill in the scratch with a clear coat pen and wet sand the excess
lol i gave up on some scratches i had.Originally Posted by LakeShore_Slate
I have my detail guy doing my car right now, he said the same thing, if your fingernail gets stuck in it, you gotta get it painted, no cheap way out. I'll keep a grand in my pocket and deal with the scratch.
it takes time you need to have it wet sanded this can also help remove/lighten the scratch. Id recommend a detailer.
Depends on how deep the scratch is. I've seen some nasty scratches come out of my car but some of them are too deep. This is what i use to get most of them out.
Quote:
Maybe I did not use it correctly (too wide an area, one inch wide), but my application of the same product made things worse as it was a poor colormatch... Ditto for painting the aftermarket backup sensors with it. I just decided to live with my bumper scratches and dings until I accumulate enough unsightly ones to "trigger" a re$pray Originally Posted by treacherous
I've actually had decent results using multiple applications of Dr Colorchip.
Quote:
Agreed. Unless it's something very minor that Sratch-X or Dr. Colorchip (YMMV) can certainly fix, it's best to go with a pro.Originally Posted by nawalvicky
