Steering wheel shake after new tires???
Old Jun 7, 2011 | 10:21 PM
cmcan22's Avatar
Long story short, I just got new Michelen tires put on my 08 G35X before my drive out to Kansas City from Connecticut. On the drive, I noticed a significant but not substantial amount of vibration coming through my steering wheel when going in the range of 60-75 mph. I figure it's due to the new tires, as they have a pretty deep tread but I'm not positive. Another one of my theories is that somehow my mechanic cracked a rim when putting the new rubber on the rims. My last thought is that the tires could just use an alignment if it wasn't done properly when the new tires were put on.
I'm pretty sure it's just due to the new tires so I'm planning on getting some new fronts when I get back to CT at the end of the summer but I'm going to eliminate the other possibilities in the meantime. What I'm wondering from my fellow G drivers is what front tires would you recommend? I'm looking for maximum grip with minimum shake/play in my wheel as I'm sure most other drivers are.
Thoughts??????
Old Jun 7, 2011 | 10:55 PM
pricojorge's Avatar
didnt read the whole thing but im just going to say ... They were not balanced correctly
tires could be bad... maybe he did crack the wheel usually its that they were not balanced
Old Jun 7, 2011 | 10:56 PM
vqsmile's Avatar
Personally, I'd never run different tires on the fronts than I have on the rears unless it was specifically for drag runs or something, but a DD, no way.
.02
Old Jun 8, 2011 | 12:02 AM
VicariousVision's Avatar
This definitely sounds like they were not balanced properly.
As for running different tires front to back - it can be done. It's not ideal I guess, but I ran mismatched tires front to rear for a long time with zero issues (and my G is my daily). I would suggest getting everything balanced first before setting your sights on new tires. Getting them balanced shouldn't cost you much (if anything) and will likely fix your problem.
Old Jun 8, 2011 | 01:28 AM
maclovio's Avatar
+2 on the balancing
Old Jun 8, 2011 | 01:31 AM
07GRider's Avatar
+3 on balancing and i also have front diff from rear .... and i ride smooth as Mr. Clean head
Old Jun 8, 2011 | 09:51 AM
Anton_Chigurh's Avatar
ah yes the steering vibration..been dealing with this for 5 months now..but yours kinda sounds like balancing..but i thought mine was balancing..spent almost $300 on balancing and that wasn't it....could be a bent rim or bad tire
Old Jun 8, 2011 | 10:36 AM
Tomek's Avatar
+1 on the balancing of the wheels, also check to make sure that your rotors are not warped or bent. When I hit a curb this winter, everything checked out OK, but I had a persistent shaking at around 70MPH. It turned out to be a bent rotor.
On to the tires check out tire rack and read the reviews of the tires, my personal All season favorites are as follows:
1. Michelin Pilot Sport A/S Plus
2. Pirelli PZero Nero All Season
3. Yokohama ADVAN S.4
4. Kumho Ecsta ASX
5. Yokohama AVID EnVigor
6. Continental Extreme Contact DWS
7. Hankook Ventus V4 ES
I think that for the money you can't go wrong with the Kumho's. However these are my suggestions and you should make your own informed decision.
Old Jun 8, 2011 | 11:54 AM
Christopher112's Avatar
100% balancing.
Old Jun 8, 2011 | 02:34 PM
GXXXV X's Avatar
+7 on Balancing
4. Kumho Ecsta ASX
ik kumhos are good but ive heard they are kinda loud? i recommend some sumi's also, they got load of good reviews too
Old Jun 8, 2011 | 02:48 PM
rpm&my_G35's Avatar
I see a lot of you are saying it's ok to run different, mismatched tires front and rears. The OP has an X model and presumably still under warranty. If he runs different tires and has transmission or differential problems (coincidence or not), Infiniti will likely void any warranty.
That being said, the guys are right, you got a bad new tire or they aren't properly balanced.
Old Jun 8, 2011 | 08:57 PM
cmcan22's Avatar
Thanks for all the advice guys. I'm going to get them balanced in the coming weeks when I can find the time and let you all know if this solves the problem. I'm hoping this is the issue so I don't have to replace a rim or sit on these Michelin's for a few years in steering misery
Old Jun 8, 2011 | 09:01 PM
dumbg35x's Avatar
u didnt say if you got them balanced or not.. but when getting new tires.. or switches rims.. its better to get them balanced.
Old Jun 9, 2011 | 04:33 PM
red00lght's Avatar
I just put Michelin Pilot pro sports on my 18" wheels and had the same problem. The damn Mieneke shop where the tires were delivered from Tire Rack hadn't balanced them correctly.
Took the car to Infiniti and they properly balanced them (for free!) and the shake was gone.
Old Jun 9, 2011 | 05:22 PM
mathnerd88's Avatar
Wait...you pay $300 for balancing? Wtf?
Balancing usually costs at most $10-$15 a tire...
You're looking at a $60 max for balancing.
Even with an alignment, you're looking at around $150 max for alignment and balancing.
Walmart does lifetime balancing for $7.50 per tire.
