View Poll Results: (5at drivers) When you downshift in DS, do you match revs?
YES! I am a skilled rev matcher!
53.33%
No. I do not know how.
40.00%
What does that mean? Dunno what DS is...
6.67%
Voters: 15. You may not vote on this poll
Rev Matching (5at)
Old Jun 15, 2011 | 02:21 PM
GXXXV X's Avatar
Rev Matching (5at)
I was just wondering who else here matches revs when they downshift in sport mode?
EDIT: (i mean rev matching before the next gear engages, causing the car to buck/slam forward for a second. rev matching for a SMOOTH downshift)
Old Jun 15, 2011 | 02:22 PM
BionicG35's Avatar
pretty sure the trans does this for you.....
Old Jun 15, 2011 | 02:30 PM
lefizzet's Avatar
+1 it does idk what OP is talking about lol
GXXXV X's Avatar
if it does do it automatically, it's not smooth AT ALL! It slams the car forward
lol maybe you guys havent tried downshifting yet...try downshifting 3>2 or 2>1 around 4500 RPM and try telling me that its a smooth shift. and no theres no problem with my tranny. even my 330ci you were able to match rpms for smooth downshifts...
Old Jun 15, 2011 | 03:06 PM
Tomek's Avatar
I downshift all the time from 3 to 2 and even 2 to 1 on occasion, and I never have to rev match manually. The auto trans does all the thinking for me, and its as smooth as butter. However I will never drop it from 2 to 1 at 4500rpm this is just asking for trouble. I sure hope that you are not dropping it from 2 to 1 when your engine is at 4500rpm on regular basis, this will send the engine too close to red line. This is not a healthy thing to do to your transmission, and yes all the automatic cars that I have driven thus far will lurch at these rpms.
Old Jun 15, 2011 | 03:17 PM
GXXXV X's Avatar
i do downshift to slow down but 4500 was just an estimate, 2>1 usually jumps to around 6000 when i dshift
Old Jun 15, 2011 | 03:18 PM
GXXXV X's Avatar
hmm this seems like a poll fail
Old Jun 15, 2011 | 03:49 PM
malice9999's Avatar
rev-matching an automatic transmission... really?
Old Jun 15, 2011 | 03:53 PM
soundmike's Avatar
Mine matches just fine unless i force it at some weird rpm/speed combo (usually very low speeds). It also works beautifully when it hits the track.
Old Jun 15, 2011 | 03:55 PM
thescreensavers's Avatar
Mr.202?
05+ 5AT rev matches for you.
Fail OP is Fail
Old Jun 15, 2011 | 08:25 PM
sTeadFasT96's Avatar
What is this guy talking about?!
Old Jun 15, 2011 | 08:35 PM
G3Sx's Avatar
Before I drove a car with paddle shifters/rev matching tranny, I never thought how convenient it could actually be. I was always under the impression that no auto could match slamming a manual from 4th to 2nd to get into the powerband and take off. So I experimented with the G, and sure enough... You can "double click" the shifter or the left paddle to downshift 2 gears at once. Please try this at your own risk. If you've never driven a stick before, perhaps you need to familiarize yourself with your gear ratios so that you know when it is safe to do so.
Old Jun 15, 2011 | 08:44 PM
jbell255's Avatar
Rev match on AT LOLz
Old Jun 15, 2011 | 09:42 PM
The car won't ever do an unsafe shift. It's not like you can go from 5th straight to 1st and blow your motor in an auto...
If the car is already high in a gear, it won't let you downshift anymore.
Old Jun 15, 2011 | 10:01 PM
G3Sx's Avatar
I beg to differ... Don't ask me how I know. There is something scary about seeing the tach creep past 8k when the factory rev limiter is at around 7600. I reacted properly though and no harm was done. The engine can safely rev to 8k, but if you start messing with downshifting by "double clicking" the left paddle at too high an rpm for a double downshift, you had better know what revs you'll end up at after the tranny drops 2 gears down.
I'm not sure if the safety was designed with downshifting more than one gear at a time in mind. So I thought I'd mention it.
