spark plugs brand recommendation
Old Jun 19, 2011 | 09:40 PM
borderline's Avatar
I've heard of NGK iridium, but is it the best performance plugs I can buy for my X?
Any inputs on the BOSH platinum:?
Old Jun 19, 2011 | 09:57 PM
vqsmile's Avatar
As long as you are getting an iridium plug with proper fit and temp range, you should be fine as there will be no noticeable difference between them. That being said, personally, I'd stick with either a Denso or an NGK.
.02
Old Jun 19, 2011 | 11:17 PM
BionicG35's Avatar
Do NOT get those garbage Bosch plugs. Buy NGK lazer series iridium or iridium IX. Denso iridium would also be a great choice.
Old Jun 19, 2011 | 11:51 PM
black_sedan's Avatar
^ I agree with both of these guys. If you're replacing plugs, how many miles are on your car? I wouldnt bother if its under 75k miles.
Old Jun 19, 2011 | 11:53 PM
42N8one's Avatar
Buy em from the dealer, they're about 12.50 a piece nothing is better than oem replacement
Old Jun 20, 2011 | 12:19 AM
faiz23's Avatar
Nooblets pay STEALRSHIP pricing. How much do you want to pay hmmmm... $12.50 x 6 = $75, Also nothing better than that right hmmmmm.....
I got you a sweet setup and saved you big MOOLA.
6 OEM NGK DENSO (Iridium-tipped type) Standard type FXE22HR11 Gap (Nominal) mm (in) 1.1 (0.043)
Carbon Cabin Filter
Mobil 1 Oil Filter
PCV Valve
Air freshener
http://shop.advanceautoparts.com/web...1740619086____
http://shop.advanceautoparts.com/web...GRPFILTAMS____
http://shop.advanceautoparts.com/web..._949175676____
http://shop.advanceautoparts.com/web..._812991074____
http://shop.advanceautoparts.com/web...A|GRP2002_____
https://g35driver.com/forums/v36-eng...007-sedan.html
https://g35driver.com/forums/g35-sed...arts-sale.html
Old Jun 20, 2011 | 06:36 AM
^ im loving those advance auto parts coupons!
Old Jun 20, 2011 | 03:57 PM
42N8one's Avatar
Without the coupon its 12 bucks a piece, blow me.
Old Jun 20, 2011 | 09:01 PM
borderline's Avatar
Good work FAIZ23!
My car have 46K and was planning to change them at around 50k.
You convinced me to stick with denso or NGK
Old Jun 20, 2011 | 09:04 PM
faiz23's Avatar
I am sorry I can't stop you from pissing your dollars away at the dealer. Enjoy and have a nice day paying retail
Old Jun 20, 2011 | 09:11 PM
BionicG35's Avatar
Iridium plugs will last 100k miles AT LEAST. Don't waste your money unless you have a misfire
Old Jun 25, 2011 | 12:57 AM
bertmauricio's Avatar
+2 on the AdvanceAuto coupon. Saved $40 on my order of plugs and other stuff.
Old Jun 28, 2011 | 01:44 AM
BuckeyeInMI's Avatar
Just got a set from Advanced for $32, excluding tax and shipping. Great discount code, knocked $20 off a $52 order. Don't know if I'll replace them yet or not, but wanted to get them while they were so cheap.
Old Jun 28, 2011 | 09:47 AM
infinitig35's Avatar
Recently I just got mine replaced with NGK platinum. My G has a little over 60,000 miles. It's almost a 10 year old car so I thought I'll be pro-active and get new plugs.
Old Jun 28, 2011 | 10:02 AM
vqsmile's Avatar
So essentially, you prematurely downgraded your plugs in an effort to be proactive on your maintenance ??
