Display Unit?
Jun 30, 2011 | 12:42 PM
Are we positive that the lcd Display Units (OEM Part #s) differ in the Nav and Non Nav cars? Either my memory is failing me (quite likely) or I never knew but simply assumed they are different.
After a bit of searching on...
- Driver.com
- InfinitiPartsUSA and InfinitiPartsOnline
- looking through the entire AUDIO, VISUAL & NAVIGATION SYSTEM section (AV.PDF) of the 07 G35 Sedan manual
...I can only find references to one Display Unit (in the 'With Navi' section) and no specific part number(s).
Thanks
Reply 0
Jun 30, 2011 | 12:53 PM
The nav is a touch screen, the non-nav is not
Reply 0
Jun 30, 2011 | 01:04 PM
Quote: The nav is a touch screen, the non-nav is not
I am aware of this but is the 'Touch' a function of the firmware and/or the control head unit. In other words if it where connected to the Navi control head unit would the touch screen be enabled, so to speak?
I am looking for evidence that there are two completely different Display Units used in Navi and Non-Navi equipped cars? Part #, pics or harness port/pin connectors.
Reply 0
Jun 30, 2011 | 02:04 PM
IIRC, the navi screen is higher resolution and uses component rgb inputs and the non-nav screen uses composite inputs. Hopefully someone else can chime in to confirm this.
Reply 0
Jun 30, 2011 | 02:06 PM
No its different screens, the hardware has to support touchscreen functions. i cant give you evidence but i can almost guarantee you that its different, im sure someone has the part#s and will chime in, maybe terry.
Reply 0
Jun 30, 2011 | 05:47 PM
I am researching this as well. I have a 2008 non-nav sedan. The shop manual says the display unit receives RGB, RGB area, and RGB synchronizing signal. I think it's an RGBHV signal similar to a computer VGA. I'm not sure though.
Reply 0
Jul 5, 2011 | 11:40 AM
Quote: IIRC, the navi screen is higher resolution and uses component rgb inputs and the non-nav screen uses composite inputs. Hopefully someone else can chime in to confirm this.
This ^
I forget the name of the other member who researched all this awhile back, but the navi lcd is completely different with different pinouts and inputs from the non-navi lcd screens.
Reply 1
