How much are front wheel bearings and how hard are they to change out?
Old Aug 16, 2011 | 08:20 PM
Anton_Chigurh's Avatar
Where did you get your bearings from for those of you that replaced them on these cars and was it a pain to switch out?
Old Aug 16, 2011 | 08:26 PM
AesonVirus's Avatar
I believe they're pressed.
I need to do one as well, assuming I ever get my car back.
Old Aug 16, 2011 | 10:07 PM
jimboG35x's Avatar
i think my front drivers sid eis goign bad i car it it making noises when driving..is it a hard thing to do.Is it under warranty iwas thinking about taking it in to se eif they cover it...
Old Aug 16, 2011 | 11:13 PM
g35sedan5at's Avatar
from what ive gathered, the bearing itself doesnt come alone, its part of the hub assembly. about $103-$150 depending where you get it and if its OEM or another brand, i.e. Timken.
theres actually a DIY on switching it out for our 2nd gens somewhere on here.
Old Aug 16, 2011 | 11:19 PM
anyone have a link? Sorry i can't find it. If it's part of the entire hub then it should be fairly easy to replace...thinking of replacing both fronts even though they may be fine...
Old Aug 17, 2011 | 03:58 AM
kool_yaar's Avatar
Come on Anton, youve been here long enough to be able to search for such simple things it was the second search result lol... Anyways here ya go: Bearing DIY Enjoy!
Why change em if they arent bad, if your car ran perfectly fine with new wheels/tires at the dealership then its either the wheels or tires and nothing to do with bearings, so why waste $$ unless needed. You can have tire shop check if your wheels are in good shape or not by having them mount the wheel without the tire on the balance machine to check for damage/out of balance wheels.
Also make sure you thank him for such a detailed DIY which should help you save $200-400.
Old Aug 17, 2011 | 01:30 PM
vqsmile's Avatar
Originally Posted by kool_yaar
come on anton, you've been here long enough to be able to search for such simple things it was the second search result lol...
Old Aug 17, 2011 | 11:44 PM
Greenlawnracing's Avatar
I'm too lazy to read the write up, but if this is anything like the Maxima the wheel bearings are usually sold only in complete kits with the hubs. However if you search hard enough (I think we bought them from AutoZone) you can get just the wheel bearings for about $50 at dealer price. It does take a press to get them out, but saves ya some money and doesn't take much time.
Old Aug 20, 2011 | 08:13 AM
sunny G-35 NYC's Avatar
Hey anton do you have any updates for us. My cars vibration is getting worse and this is one of the parts I have on my list to change out. If you are still looking for where to purchase these you might want to checks out infinitipartsusa.com because they have it for 143.00 each
Old Aug 20, 2011 | 11:40 AM
da mayor's Avatar
sunny come see me and order them ill hook you up at my dealership
i have 6 sets in stock... talk to ohh noes for the install on g35nyc
Old Aug 20, 2011 | 06:27 PM
No update but told by another dealer that it's my wheels and tires as they put them on my car from other car on lot and it was gone or so they said.... Even though i think it runs deeper..idk anymore..i am so sick of chasing this vibration
Old Aug 23, 2011 | 08:35 PM
TunaG35's Avatar
try your wheel bearings. nissan said my front left is GONE and i have some virbrations issues at 85+. so next week their fixing it. and they said that could be the culprit to whats causing the vibrations.
Old Aug 23, 2011 | 08:44 PM
bluedevils95's Avatar
I am not sure on our G's but on my Acura i changed out my own bearing.
Old Aug 23, 2011 | 09:30 PM
i went to the dealer today with a humming sound and they replaced BOTH front hubs under warranty. im 500 miles short of 60k so thank god i took it now.
Old Aug 23, 2011 | 09:34 PM
I am at the stange now where i have to replace part by part to fix my issue..breaks and bearings are next on list..along with other wheels and tires..i guess....
