I washed and dried my key fob...
Old Aug 22, 2011 | 02:30 AM
cnugs127's Avatar
twice. Accidentally of course. Luckily both times the remote continued to work normally. Has anyone done this as well?
Old Aug 22, 2011 | 02:45 AM
kool_yaar's Avatar
No, but i left it out in pouring rain totally uncovered and buttons facing up while i was playing some football with my friends for over an hour and it thought it would be the end of it but it has had no problems since.
Old Aug 22, 2011 | 09:25 AM
rbayne's Avatar
The way they are made, there is a rubber gasket that protects them from getting wet on the inside. Unless you have opened them before and not put back correctly, the chances of water getting in is slim.
Old Aug 22, 2011 | 11:14 AM
cnugs127's Avatar
that's good to know about the water thing. what about the heat thing? wouldn't most electronic devices go haywire after being in a drier for over an hour?
Old Aug 22, 2011 | 12:48 PM
gtbigup01's Avatar
Originally Posted by cnugs127
twice.
Nah we tend to only screw up the same thing ONCE. Kidding dude. Nah never did that but I can see it happening quite easily.
Old Aug 22, 2011 | 12:52 PM
rbayne's Avatar
I would think so, maybe he only had ot on low heat.
Old Aug 22, 2011 | 12:55 PM
bluedevils95's Avatar
WOW! That is good to know that these key fob can really take some abuse! Not that i am going to abuse them.
Old Aug 22, 2011 | 01:10 PM
bfos's Avatar
I went swimming with mine! So stupid, but it had no problems. I was shocked.
Old Aug 22, 2011 | 01:47 PM
salvador312's Avatar
I peed on mine, still works fine!!
Old Aug 22, 2011 | 01:49 PM
PAIXAO's Avatar
I went swimming with mine in my pocket. Totally forgot it was there. Worked just fine afterwards.
Old Aug 22, 2011 | 02:02 PM
gtbigup01's Avatar
Add one of these bad boys ($7) and you're safe from little sprinkles, can't say it'll help in the pool . It seems like they survuve just fine in pools and washers without this cover. This just helps with absorbing shock if dropped.
Old Aug 22, 2011 | 02:08 PM
gshadyz's Avatar
fu*k your question i can stare at you avatar for dayz
Old Aug 22, 2011 | 02:16 PM
gtbigup01's Avatar
^^ LMFAO it's a dude in the pic
Old Aug 22, 2011 | 02:17 PM
ilovez33's Avatar
Washed mine and its toast :-\
Old Aug 22, 2011 | 02:50 PM
gtbigup01's Avatar
Please say you didn't just go try it to see if it'll really be fine hahaha.
