2008 G35x Low Idle/Turns Off Cleaned the TB and now the AC wont turn on
Old Aug 23, 2011 | 02:46 PM
GErwin's Avatar
I need some help! I have a 2008 G35x with about 70k and its having some issues. The first problem was a low idle that would result in engine stalls. I read some forms on here, disconnected the battery, cleaned the throttle bodies, and it seemed to fix the problem (for now). My wife drove the car to work the next day and the AC isnt working. I think something is up with the computer. Also, the backlight for the gauges decides to go on and off. I think the car may be possessed. Anyone have any ideas?
Thanks!
Old Aug 23, 2011 | 03:20 PM
kool_yaar's Avatar
There actually is a TSB for this thing, if cleaning TB does not help then it needs some sort of ecu reflash under warranty, just go to the dealer and explain the issue and they should take care of it, as for the AC and gauges lights, it could be some electrical issue or just a bad cluster.
You should still be under the drivetrain warranty under which this stalling should be covered without a hitch at least
Old Aug 23, 2011 | 04:32 PM
RemmyZero's Avatar
if you never noticed an issue with the AC or cluster before just check your fuses to be sure, but it should be un-related to the work you did.
Old Aug 23, 2011 | 04:52 PM
GErwin's Avatar
Do you know where I can find what it says for that TSB? Im not under warranty anymore and dont want to fork out the cash at the dealer
Old Aug 30, 2011 | 05:46 PM
GErwin's Avatar
Update
So I cleaned the throttle bodies, the MAF sensors and changed the air filters. The idle was better for a few days but then went back to stalling. I took it to the infinity shop and had to explain to them the TSB. After $102 and the software update it is running much better! And I'm getting almost 4mpg better at 22. Now we will see how long it lasts...I've only had the car back for a day
Old Aug 30, 2011 | 08:08 PM
kool_yaar's Avatar
^ glad to hear its back to normalk and hope it stays that way, but why did they charge you $102? Was it for the TSB itself or for 'diagnose'? since i realize you are out of warranty.
Old Aug 30, 2011 | 08:37 PM
GErwin's Avatar
They charged me for the TSB. I basically had to tell them what to do.
Old Aug 30, 2011 | 08:40 PM
kool_yaar's Avatar
yeah iv heard of that before and sounds TERRIBLY unfair! Considering that this(like all other TSB) is a known problem with a selected batch of vehicles that infiniti themselves have identified and made the dealer and consumer aware of it through this TSB, but will only perform the service free of charge if youre under warranty even though its a common problem and a fault on their part and nothing to do with the user... sad
Old Aug 30, 2011 | 11:49 PM
bluestacy04's Avatar
Let me add this in the pot. When I got mine done I was out of warranty (due to mileage) and didnt pay a dime. The dealer told me that Infiniti picks up the cost on TSB's???
Old Aug 31, 2011 | 12:07 PM
kool_yaar's Avatar
^ yeah thats they issue, it seems to be dealer dependent on whether or not they will cover it which is the most frustrating part.
johnjohn077
Brakes
Aug 4, 2015 01:37 AM
keresa777
Jul 27, 2015 09:04 AM
rping
Jul 26, 2015 09:53 PM
richmc
Jul 26, 2015 08:13 PM
newbdriver01
Jul 15, 2015 06:10 PM
