Pic of lowered G
Old Aug 23, 2011 | 05:17 PM
GBoy's Avatar
Pic of lowered G
It looks perfect, what do you guys think this could be lowered on.
Old Aug 23, 2011 | 05:19 PM
GBoy's Avatar
Old Aug 23, 2011 | 05:24 PM
rpm&my_G35's Avatar
Eibach Pro Kit is like that.
Old Aug 23, 2011 | 05:36 PM
pbabajan's Avatar
+1 ^looks like eibach
Old Aug 23, 2011 | 05:55 PM
GeeWillikers's Avatar
Walking The Fine Line...
Personally don't think it looks perfect, but to each their own.
Old Aug 23, 2011 | 06:11 PM
GBoy's Avatar
We are all different, I don't like the wedge look, so it looks like Eibach, I could not figure out if it was HR, Eibach or Tanabe, do you need a camber kit with the Eibachs?
Thanks
GBoy
Old Aug 23, 2011 | 07:55 PM
rpm&my_G35's Avatar
Thanks
GBoy
There are dozens of threads with varying opinions. Search for "Camber"
If you don't mind having camber a hair above the upper limit of neg camber specs then you will not need a camber kit. Obviously your tires will wear out a little sooner and the tire brand and type will also be a factor.
Some guys get the adjustable (SPC/Eibach) rear camber arm and toe bolt kit because it doesn't cost very much but they avoid replacing the front arm because they are fairly expensive.
Basically you will get about a half dozen different opinions on whether you need camber kits with a 1.5"F, 1.2"R drop.
FWIW, I just asked this highly qualified master mechanic who specializes in Nissan/Hyundai this question and here is his reply a couple days ago.
"Hi ****, you should install a front and rear camber kit because that drop will bring in the camber to negative it really is advisable to do most guys go through a set of tires and then wind up putting them in when it’s too late.
Cheers
Old Aug 23, 2011 | 08:19 PM
pbabajan's Avatar
H&R Drop is noticably lower than this
Old Aug 23, 2011 | 08:34 PM
soundmike's Avatar
Isn't that a stock photo from Infiniti? Looks OEM height to me.
Old Aug 23, 2011 | 08:44 PM
BionicG35's Avatar
Lmfao 100% bone stock
Old Aug 23, 2011 | 10:26 PM
apexi957's Avatar
Doesn't look OEM height..
Old Aug 23, 2011 | 10:33 PM
KuroV36's Avatar
I didn't think that was oem height at first but I found this page with those set of pictures
http://www.carwallpapers.cc/index.ph...g35-sedan-2008
mine looks way more 4x4ish than this sedan
Old Aug 23, 2011 | 10:40 PM
broke_as_ajoke's Avatar
the back is lower than the front.. is that normal for eibach springs on a 4 door. I have the pro kits on my coupe.. and the drop is not low in the back for me
Old Aug 23, 2011 | 11:22 PM
rpm&my_G35's Avatar
Laugh all you want...it's not stock height in that pic. My S sedan is nowhere near that low and that's why I have Eibachs sitting in my garage waiting to go on.
I attached a pic below, of the S sedan on Eibach Pro Kit
OEM G sedan (sport)
Old Aug 24, 2011 | 12:10 AM
pbabajan's Avatar
No way that this is stock look at the gap at the tire and fender
