07 G35 Sedan Wheel Bearing Issue...
You might also call a Nissan service shop as they are more abundant than Infinity dealerships. Actually, the stealerships are the last place I would check. I am not aware of any special skills involved in repairing the hubs on an infinity, so I would also google your zip code and auto repair shops. Ask around (work, autozone, parts stores) if anybody knows of a good shop. My local tireshop/mechanic said he would do my mountaineer for about $150ish a wheel. It is an AWD also.
Good luck
Good luck
If there is NTB around also, check them, usually reasonable rates, they did my Ford Taurus and I think it was 500 out the door, granted parts a little cheaper since it was older and easier to get those parts just the bearing, don't just settle for any place, check around before you settle on a place!
Phil
Phil
Also, the OP is getting pricing for replacing BOTH front hubs, so the cost is twice what some others are referencing.
150/Wheel is about normal for Hubs.
DIY and save $$$. Pics of ABS sensor are in this. Can't imagine what is the problem other than planning on having issues removing it. Those screws break easily because steel in aluminum is hard to remove. You can DIY, just be gentle and use PB Blaster on the ABS screw.
https://g35driver.com/forums/g35-sed...l?ref=esp-link
I did a search and saw previous threads.. still a little confused. I get the noise and everything but now its at the pricing stages and I always get taken advantage of because I don't know much.
first, Aamco said its the front two wheel bearings, for parts and labor they want $1,200... Pep boys is saying close to 1k... im looking online and some of these threads, and I see people talking about getting wheel bearings for $150??? i dont get it, am I missing something?
Please someone get back to me!!!! MY CAR IS OUT OF WARRANTY TOO!
Anyways, it's covered under the power train 6 year/70k mile warranty. If your car has less than 70k miles, they should be doing it for free.
#30
How long can I travel with this front bearing noise? It started about 500 miles ago, now it is rather noisy, though not to much. I need to travel back to home another 500 miles and I'm a little bit afraid if the bearing could stuck or something else bad could happen? Maybe I shouldn't drive faster than 60-80mph at the way home, should I?
