caster kit
Old Sep 24, 2011 | 12:05 AM
freakta's Avatar
caster kit
so i have been to get an alignment and my caster is pretty far off. so ive been told there is no way to adjust it from the factory.
there must be an aftermarket kit to adjust this on the car.
who makes it? how much is it? and is it worth it?
Old Sep 24, 2011 | 03:18 AM
kool_yaar's Avatar
Im guessing your camber is off rather than caster... are you lowered on springs, coilovers? if so you will need to buy a camber kit with toe bolts if you want to bring your car back within limits these can run you about ~$300-500 depending for both front and rear.
If you are not lowered than they should be able to get the car back into spec, if not try a better alignment shop.
Old Sep 24, 2011 | 11:44 AM
freakta's Avatar
its bone stock just got a good amount of miles on it... ive been to town fair tire twice and they keep saying that the caster is out of spec and its non adjustable.
if i knew of a better alignment shop id go... any suggestions
Old Sep 24, 2011 | 12:16 PM
terrycs's Avatar
New upper control arms such as the one made by SPC will give you all three adjustments. Not cheap though.
Your caster shouldn't be out of spec if it is bone stock. There is some play in the bolt to hole clearances, so a good alignment shop will try and take advantage of that before telling you it's just not adjustable.
Diode Dynamics
Accessories-Vendor
39
Nov 30, 2021 02:28 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
Extreme Dimensions
Exterior-Vendor
Oct 29, 2015 10:24 AM
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
JG_G35
Engine - Intake/Fuel
Sep 7, 2015 09:35 PM
