Warrant almost up
Old Oct 12, 2011 | 03:15 PM
mrclowny's Avatar
My warranty is up at the end of the month and I plan to stop by the dealer next week. I don't really have much issues other than the Shift **** that won't move from P to D very well when the car is started. My guauge cluster dash is lifting in the corner but this is a known issue.
Old Oct 12, 2011 | 03:40 PM
rpm&my_G35's Avatar
Originally Posted by NationsMostWanted
So they are denying my rattling noises exists and Infiniti is sending out there own inspector to see if my cluster or paddle shifter should be replaced. Its pathetic that Infiniti has to stoop to this level when it is still under warranty. So in a few weeks Ill redrop it off and they will recheck it to verify if the dealer is wrong or if I am wrong.
All I know is that I will never buy another Infiniti after this
It's their strategy to get the customer flustered to the point that they say "OK forget it, don't bother". Many customers would rather not pursue some issues beyond the point of the dealership. If you politely persist you will get your way, 9 out of 10 times.
Good luck
Old Oct 12, 2011 | 04:22 PM
J2S2M's Avatar
- Dried/cracky seal in the sunroof which lead to creaky noises when driving over any imperfections on the road. (They replaced the whole sunroof)
- Creaky/squeaky center console and shift trim area. (Insulated with filling material)
- Loose weatherstripping around the inner part of the driverside rear door. (Replaced w/ new parts)
- Oxidation in the headlight. (Replaced w/ new headlights)
- Loose chrome piece at the bottom part of the front windows. (Replaced w/ new trim)
- Crackly buzzing noise in the steering wheel. (Replaced w/ new steering wheel)
- Peeling from door pulls and steering wheel. (Replaced w/ new parts)
- Gauge cluster cover lifting on left side. (Replaced w/ new cover)
- Brake squeeling/vibrations. (Replaced under TSB)
That's about everything I can think of at the moment. But I am sure I had more.
Old Oct 12, 2011 | 04:33 PM
NationsMostWanted's Avatar
Yea we meeting coincidently on the day my warranty is up. I'm going make them drive it with me the day I drop it off.
cool35S
Dec 6, 2005 01:51 PM
