Got the itch to mod (new owner)
Old Oct 10, 2011 | 11:13 AM
funkydrummer's Avatar
So, I've fought the urge for a month now, but I'm gonna have to go ahead to treat the new girl to something tasty.
I'm looking for good bang for my buck, and would like some added hp, and maybe a little extra sound if it's resonable and tasteful.
Intake a good choice for my first mod? I know most people like the Stillen duals, and they look awesome, but are a little pricey. Can anyone offer advice on the other intakes like Fujita, R2C, Injen, JWT, etc.? Or point me in the right direction? Or, are the Stillen just the way to go?
Other mods like HFC a better option for some power?
Old Oct 10, 2011 | 12:05 PM
vqsmile's Avatar
Originally Posted by funkydrummer
I'm looking for good bang for my buck, and would like some added hp, and maybe a little extra sound ...
If you're looking for good value, relatively speaking, you're not going to find it for added hp; some extra sound maybe, but not hp.
Old Oct 10, 2011 | 02:14 PM
rvanderwerf's Avatar
Best think you can do for more HP is cat delete/TP (HFC if you live in CA or a actual smog sniffer state) and exhaust. Everything else is pretty tiny gains. For handling, get some sways, then I'd go coilovers and wheels
For intake, it seems like none of them give any gains, although uprev claims the stillen gen3 will get you some (see the epic intake thread). IMO 500 bucks for so little hp isn't worth it, but the sounds it adds is very agressive and a lot of people like it.
Old Oct 10, 2011 | 03:06 PM
I guess I should mention I've got an 07 X...
I'll have to look for that epic intake thread, but from the little bit of reading I've done I thought some of the intakes are claiming 5-10WHP gains. I need to change my air filter anyway, may go ahead and consider the R2C or one of the more affordable ones.
I would definitely like to reduce some of the understeer and add some more stability, but don't really want a much harsher ride (daily driver)...what are the sway bar options for a G35X? Can anyone comment on the effect of new sways on the X?
Old Oct 10, 2011 | 03:50 PM
bluedevils95's Avatar
Well if you want power all i did was install injen cai and fast intention exhaust. And iam putting 309 to the wheels at churches dyno
Old Oct 10, 2011 | 04:03 PM
vqsmile's Avatar
Well if you want power all i did was install injen cai and fast intention exhaust. And i am putting 309 to the wheels at churches dyno
Well, as long as you qualify it as being on their dyno rather than true whp, your comment is valid, but it sounds like Churches dyno needs still to get proper correction factors or a recalibration.
(If you have any doubts, just google it. They're known for inflated numbers)
Old Oct 10, 2011 | 04:50 PM
G3065's Avatar
Welcome first off!
I've got the stillen gen 3 and berk resonated test pipe's and here is my two cents...
Not like I have done much on this car but if I were to remake the decision on the parts I bought I would
not get the stillen gen 3 intake instead a SRI because It's alot of work to install if you don't have the right tools for and the whole rain factor. SRI's are generally safer for the engine imo but then again gains may be a little less with that said... how much more are you really going to get out of a cai. I would go fully with exhaust components they are more fairly priced and the gains are a bit more noticeable.
My next addition will be a y-pipe not because I'm bored but curious as to what little changes will be made to the sound of the car and the hp gain.
Old Oct 10, 2011 | 11:21 PM
Ok you want better power? Just go twin turbo or supercharge. I am going to do that. Not sure when but it's going to happen soon.
Old Oct 10, 2011 | 11:42 PM
gary c's Avatar
Welcome to DRIVER, Funky!
Oh no, not the mod itch....
Intakes don't offer anything other than sound but it's worth the price. Exhaust, MotorDyne is the way to go, best quality and sound along with additional RWHP....but like all quality mods it ain't cheap. If you can afford the MD exhaust maybe you'd like his ART pipes. Now is a good time to get a Osiris tune, cost is $500+ but you will gain no less than 25 RWHP and it feels so good under your right foot!
Gary
Old Oct 10, 2011 | 11:44 PM
kendroz's Avatar
1. HFC or TP (berk or gtm) ~ 370.00
2. HKS Dry filters or K&N Oiled ~ 55.00
3. HPS Silicone hose ~ 110
4. Exhaust Fast Intentions all the way ~ 1,300
5. Osiris Tune ~ 500 to 700
The sum is around 2,600 bucks = 40 to 45 whp
More power ?
6,200 for supercharger + install ?? = a lot
Your choice
Old Oct 10, 2011 | 11:59 PM
faiz23's Avatar
More power ?
Your choice
Better option but still a lot
Momentum Performance Turbo Kit: GT35R TurbO
FIC 775cc Injectors
New Aeromotive 340 HP Fuel Pump
Custom UpRev Tune w/ License
PS Turbine Blanket - To reduce temps
Installation
Configuration
$8,649 Installed
$7,995 Installed! > FOR A VERY VERY VERY LIMITED TIME!
https://g35driver.com/forums/florida...turbo-kit.html
Old Oct 11, 2011 | 01:55 AM
Highestrich4's Avatar
Do they have turbo kits out for the vq36 sedans? I wanna try and piece something together when i get mine. I dont want amazing power but something to make the tires squeal
Old Oct 11, 2011 | 08:56 AM
Thanks for all the replies, some good info!
How does the Osiris tune work? Do you have to ship off your ECU? What does it change, timing, fuel trim? I'd love to go FI, but at this point I can't justify the cost.
Sounds like HFC or resonated test pipes might be a good choice for me...but what will the sound/volume be like with those options? Do the test pipes make the exhaust smell? Are they really raspy?
What's the added power difference HFC vs. test pipes?
Old Oct 11, 2011 | 09:20 AM
rhampsterwha2's Avatar
test pipes have better air flow to HFC
as mentioned before if you live in a smog check state HFC are the way to go, UNLESS you have the $$$ and can get the Motordyne XYZ w/ HFC option then you can run test pipes and still pass smog
i agree with Garry Motordyne products are the way to go they yield the best gains and their exhausts sound nice, Fast intentions is a very close second
Old Oct 12, 2011 | 09:36 PM
djfarhan's Avatar
post pics!
